Ana içeriğe geç
HTC SMT 6175 Keyboard Replacement
Neye ihtiyacın var
  1. HTC SMT 6175 Keyboard Replacement, Back Case: adım 1, 1 resimden 1.
    • First, flip the phone over so that the back is facing upwards.
  2. HTC SMT 6175 Keyboard Replacement: adım 2, 2 resimden 1. HTC SMT 6175 Keyboard Replacement: adım 2, 2 resimden 2.
    • Using both thumbs, push the back side of the phone's exterior up and remove the front face of the phone.
  3. HTC SMT 6175 Keyboard Replacement, Battery: adım 3, 2 resimden 1. HTC SMT 6175 Keyboard Replacement, Battery: adım 3, 2 resimden 2.
    • Insert your finger or a pry tool into the slot above the battery. Remove it and set aside.
  4. HTC SMT 6175 Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. HTC SMT 6175 Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • To remove the back casing inside the phone, remove the six screws around the perimeter.
  5. HTC SMT 6175 Keyboard Replacement: adım 5, 2 resimden 1. HTC SMT 6175 Keyboard Replacement: adım 5, 2 resimden 2.
    • Carefully pull off the back casing.
    • This step may be difficult. Start pulling the back out from the front shell. As it starts to lift up, move the phone side-to-side until the whole back is free.
  6. HTC SMT 6175 Keyboard Replacement: adım 6, 2 resimden 1. HTC SMT 6175 Keyboard Replacement: adım 6, 2 resimden 2.
    • Remove the top screw.
    • Be CAREFUL, because the LCD screen is attached to the front side of the motherboard by a flexible ribbon cable.
  7. HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: adım 7, 3 resimden 1. HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: adım 7, 3 resimden 2. HTC SMT 6175 Keyboard Replacement, QWERTY Keyboard: adım 7, 3 resimden 3.
    • Pull the plastic keyboard away from the front case.
  8. HTC SMT 6175 Keyboard Replacement, Navigation Keys: adım 8, 3 resimden 1. HTC SMT 6175 Keyboard Replacement, Navigation Keys: adım 8, 3 resimden 2. HTC SMT 6175 Keyboard Replacement, Navigation Keys: adım 8, 3 resimden 3.
    • To remove the navigation keys on the front of the phone, remove the four screws securing the navigation keys using a Phillips screwdriver.
    • Remove the navigation keys from the front of the phone.
    • They should pop out as a unit.
Sonuç
Luke Plewa
116 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-29, Garner Spring 2011 Cal Poly, Team 25-29, Garner Spring 2011 üyesi
CPSU-GARNER-S11S25G29
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 1,678
