Ana içeriğe geç
HTC Surround Sim Card Replacement
Neye ihtiyacın var
  1. HTC Surround Sim Card Replacement, Back Case: adım 1, 2 resimden 1. HTC Surround Sim Card Replacement, Back Case: adım 1, 2 resimden 2.
    • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
    • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
  2. HTC Surround Sim Card Replacement: adım 2, 3 resimden 1. HTC Surround Sim Card Replacement: adım 2, 3 resimden 2. HTC Surround Sim Card Replacement: adım 2, 3 resimden 3.
    • Using a Phillips #00 screwdriver, remove the screws as directed.
  3. HTC Surround Sim Card Replacement: adım 3, 1 resimden 1.
    • Separate the screen and back cover with the opening tool.
  4. HTC Surround Sim Card Replacement, SD Card: adım 4, 3 resimden 1. HTC Surround Sim Card Replacement, SD Card: adım 4, 3 resimden 2. HTC Surround Sim Card Replacement, SD Card: adım 4, 3 resimden 3.
    • Look at the bottom right hand corner of the device and remove the silver tape covering the SD card slot with your fingers.
    • Insert the plastic opening tool directly underneath the orange surface below the SIM card until its removed from the surface of the device.
  5. HTC Surround Sim Card Replacement: adım 5, 2 resimden 1. HTC Surround Sim Card Replacement: adım 5, 2 resimden 2.
    • To get to the attachment that the SD/SIM card is attached to; insert the plastic opening tool underneath the lower motherboard until it is removed from the bottom half of the device.
    • You will notice the SD/SIM card is attached to the lower motherboard by a yellow piece of tape. Remove the tape from the back of motherboard with your fingers.
  6. HTC Surround Sim Card Replacement, Sim Card: adım 6, 1 resimden 1.
    • The SIM card slot will come off the device with the SD card slot and is ready to replace.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 187
