Ana içeriğe geç
HTC Thunderbolt MicroSD Card Replacement
Neye ihtiyacın var
  1. HTC Thunderbolt MicroSD Card Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt MicroSD Card Replacement: adım 2, 1 resimden 1.
    • Lift and remove the rear panel.
  3. HTC Thunderbolt MicroSD Card Replacement, Battery: adım 3, 2 resimden 1. HTC Thunderbolt MicroSD Card Replacement, Battery: adım 3, 2 resimden 2.
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: adım 4, 2 resimden 1. HTC Thunderbolt MicroSD Card Replacement, MicroSD Card: adım 4, 2 resimden 2.
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt MicroSD Card Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
Sonuç
Vanessa
60 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-45, Regan Winter 2013 Cal Poly, Team 19-45, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G45
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 1,568
