Ana içeriğe geç
HTC Thunderbolt Rear Frame Replacement
Neye ihtiyacın var
  1. HTC Thunderbolt Rear Frame Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Insert the plastic opening tool into the top of the Thunderbolt near the power button.
    • Gently pry up on the rear panel around the edges until it is loose.
  2. HTC Thunderbolt Rear Frame Replacement: adım 2, 1 resimden 1.
    • Lift and remove the rear panel.
  3. HTC Thunderbolt Rear Frame Replacement, Battery: adım 3, 2 resimden 1. HTC Thunderbolt Rear Frame Replacement, Battery: adım 3, 2 resimden 2.
    • Using the plastic opening tool, lift up the battery from the bottom near the kickstand.
    • Remove the battery from the inner frame.
  4. HTC Thunderbolt Rear Frame Replacement, MicroSD Card: adım 4, 2 resimden 1. HTC Thunderbolt Rear Frame Replacement, MicroSD Card: adım 4, 2 resimden 2.
    • Use your finger to push the MicroSD card in towards the top of the phone, allowing it to be released from the casing.
  5. HTC Thunderbolt Rear Frame Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to grab onto the MicroSD card and carefully remove it from the casing.
  6. HTC Thunderbolt Rear Frame Replacement, Rear Frame: adım 6, 1 resimden 1.
    • Remove the six Phillips screws from the perimeter of the rear frame.
    • By removing the screw with the "void" sticker on it, your Thunderbolt will no longer be covered under warranty.
  7. HTC Thunderbolt Rear Frame Replacement: adım 7, 2 resimden 1. HTC Thunderbolt Rear Frame Replacement: adım 7, 2 resimden 2.
    • Insert the plastic opening tool into the bottom of the phone underneath the soft keys.
    • Gently pry up on the plastic cover by sliding the plastic opening tool across the bottom of the phone.
    • Remove the plastic cover.
    • The plastic cover will have adhesive on it making it difficult to remove.
  8. HTC Thunderbolt Rear Frame Replacement: adım 8, 1 resimden 1.
    • Remove the two Phillips screws where the plastic cover was.
  9. HTC Thunderbolt Rear Frame Replacement: adım 9, 2 resimden 1. HTC Thunderbolt Rear Frame Replacement: adım 9, 2 resimden 2.
    • Insert the plastic opening tool in between the screen and the frame on the side of the phone.
    • Slowly slide the the plastic opening tool along the side of the phone until the screen begins to separate from the frame.
    • Do the same for the opposite side of the phone.
  10. HTC Thunderbolt Rear Frame Replacement: adım 10, 3 resimden 1. HTC Thunderbolt Rear Frame Replacement: adım 10, 3 resimden 2. HTC Thunderbolt Rear Frame Replacement: adım 10, 3 resimden 3.
    • Carefully separate the screen and phone from the rear frame, starting from the bottom.
    • Gently pull down on the phone and screen to fully separate it from the rear frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brandon Younger
212 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-45, Regan Winter 2013 Cal Poly, Team 19-45, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G45
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 522
