Ana içeriğe geç
HTC Touch Front Buttons Replacement
Neye ihtiyacın var
    1. HTC Touch Front Buttons Replacement, Front Buttons: adım 1, 1 resimden 1.
      • Using your finger, remove the back panel by sliding it up.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Touch Front Buttons Replacement: adım 2, 1 resimden 1.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Touch Front Buttons Replacement: adım 3, 1 resimden 1.
      • Remove the four screws in the corners of the phone using the T5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Touch Front Buttons Replacement: adım 4, 2 resimden 1. HTC Touch Front Buttons Replacement: adım 4, 2 resimden 2.
      • Use the plastic opening tool to remove the front panel from the phone.
      • Unplug the front button cable from the inside of the phone.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Touch Front Buttons Replacement: adım 5, 1 resimden 1.
      • Remove the two screws from the back of the front panel using the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Touch Front Buttons Replacement: adım 6, 1 resimden 1.
      • Remove the small circuit board by gently pushing on the center button on the front of the phone.
      FixBot'a Sor
      Yorum Ekle
    7. HTC Touch Front Buttons Replacement: adım 7, 1 resimden 1.
      • Remove the buttons by pushing on them from the front side of the phone.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Brooks
104 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-12, Regan Spring 2011 Cal Poly, Team 15-12, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G12
4 Üyeler
45 adet Kılavuz yazıldı
1Rehber Yorum
I need the keypad flex cable. Where to buy. Please guide smahapatra2012@gmail.com
subhas mahapatra - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 47
Her zaman: 3,312
