Ana içeriğe geç
HTC Touch LCD Screen Replacement
Neye ihtiyacın var
  1. HTC Touch LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Remove the back panel by sliding it up.
  2. HTC Touch LCD Screen Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
  3. HTC Touch LCD Screen Replacement: adım 3, 1 resimden 1.
    • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
  4. HTC Touch LCD Screen Replacement: adım 4, 2 resimden 1. HTC Touch LCD Screen Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to remove the front panel from the phone.
    • Be sure to unplug the front button cable from the inside of the phone.
  5. HTC Touch LCD Screen Replacement: adım 5, 1 resimden 1.
    • Unscrew the 2 torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
  6. HTC Touch LCD Screen Replacement: adım 6, 2 resimden 1. HTC Touch LCD Screen Replacement: adım 6, 2 resimden 2.
    • Separate the motherboard from the black plastic casing.
    • Unplug the black and red wire from the motherboard.
    • Unplug the black and red wire from the black plastic casing.
  7. HTC Touch LCD Screen Replacement: adım 7, 1 resimden 1.
    • Lift the black lever next to the orange ribbon cable to remove the LCD screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
callum rowland
247 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-12, Regan Spring 2011 Cal Poly, Team 15-12, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G12
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 10,864
