Ana içeriğe geç
HTC Touch Motherboard Replacement
Neye ihtiyacın var
    1. HTC Touch Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
      • Remove the back panel by sliding it up.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Touch Motherboard Replacement: adım 2, 1 resimden 1.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Touch Motherboard Replacement: adım 3, 1 resimden 1.
      • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Touch Motherboard Replacement: adım 4, 2 resimden 1. HTC Touch Motherboard Replacement: adım 4, 2 resimden 2.
      • Use the plastic opening tool to remove the front panel from the phone.
      • Unplug the front button cable from the inside of the phone.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Touch Motherboard Replacement: adım 5, 1 resimden 1.
      • Unscrew the 2 torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Touch Motherboard Replacement: adım 6, 2 resimden 1. HTC Touch Motherboard Replacement: adım 6, 2 resimden 2.
      • Separate the motherboard from the black plastic casing.
      • Unplug the black and red wire from the motherboard.
      • Unplug the black and red wire from the black plastic casing.
      FixBot'a Sor
      Yorum Ekle
    7. HTC Touch Motherboard Replacement: adım 7, 1 resimden 1.
      • Lift the black lever next to the orange ribbon cable to remove the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    8. HTC Touch Motherboard Replacement: adım 8, 1 resimden 1.
      • Remove the camera lens from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
callum rowland
253 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-12, Regan Spring 2011 Cal Poly, Team 15-12, Regan Spring 2011 üyesi
CPSU-REGAN-S11S15G12
4 Üyeler
45 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 42
Her zaman: 8,178
