Ana içeriğe geç
HTC Touch Pro 2 Housing Replacement
Neye ihtiyacın var
    1. HTC Touch Pro 2 Housing Replacement, Battery: adım 1, 3 resimden 1. HTC Touch Pro 2 Housing Replacement, Battery: adım 1, 3 resimden 2. HTC Touch Pro 2 Housing Replacement, Battery: adım 1, 3 resimden 3.
      • Apply pressure and slide upward to remove back cover.
      • Lift the back cover up away from the phone.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Touch Pro 2 Housing Replacement: adım 2, 2 resimden 1. HTC Touch Pro 2 Housing Replacement: adım 2, 2 resimden 2.
      • Lift battery upward on the upper right-hand side to remove it.
      • Check the battery to make sure there's no bent corners.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Touch Pro 2 Housing Replacement, Housing: adım 3, 2 resimden 1. HTC Touch Pro 2 Housing Replacement, Housing: adım 3, 2 resimden 2.
      • Using a T5 screwdriver, remove the four screws in corners as shown.
      • Lift the top portion of the rear case.
      • Potential for device damage: There is a ribbon attached on the back of this part that requires caution to remove.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Touch Pro 2 Housing Replacement: adım 4, 3 resimden 1. HTC Touch Pro 2 Housing Replacement: adım 4, 3 resimden 2. HTC Touch Pro 2 Housing Replacement: adım 4, 3 resimden 3.
      • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
      • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
      • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Melinda Phan
438 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-64, Walters Spring 2011 Cal Poly, Team 9-64, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G64
5 Üyeler
81 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 4,327
