Ana içeriğe geç
HTC Touch Pro 2 Logic Board Replacement
Neye ihtiyacın var
  1. HTC Touch Pro 2 Logic Board Replacement, Battery: adım 1, 3 resimden 1. HTC Touch Pro 2 Logic Board Replacement, Battery: adım 1, 3 resimden 2. HTC Touch Pro 2 Logic Board Replacement, Battery: adım 1, 3 resimden 3.
    • Apply pressure and slide upward to remove back cover.
    • Lift the back cover up away from the phone.
  2. HTC Touch Pro 2 Logic Board Replacement: adım 2, 2 resimden 1. HTC Touch Pro 2 Logic Board Replacement: adım 2, 2 resimden 2.
    • Lift battery upward on the upper right-hand side to remove it.
    • Check the battery to make sure there's no bent corners
  3. HTC Touch Pro 2 Logic Board Replacement, Housing: adım 3, 2 resimden 1. HTC Touch Pro 2 Logic Board Replacement, Housing: adım 3, 2 resimden 2.
    • Using a T5 screwdriver, remove the four screws in corners as shown.
    • Lift the top portion of the rear case.
    • There is a ribbon attached on the back of this part that requires caution to remove.
  4. HTC Touch Pro 2 Logic Board Replacement: adım 4, 3 resimden 1. HTC Touch Pro 2 Logic Board Replacement: adım 4, 3 resimden 2. HTC Touch Pro 2 Logic Board Replacement: adım 4, 3 resimden 3.
    • Using an IfixIt Plastic Tool, detach the plastic casing from the keyboard. This may require some force.
    • Using a spudger or other thin tool, carefully pry up ZIF connectors as shown. This will allow the black ribbons to detach from the keyboard.
    • Slide the two parts away from each other so that the black ribbons slide through the slots and you will now have housing into two parts.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Melinda Phan
438 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-64, Walters Spring 2011 Cal Poly, Team 9-64, Walters Spring 2011 üyesi
CPSU-WALTERS-S11S9G64
5 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 4,540
