Ana içeriğe geç
HTC Touch Pro CDMA Keyboard Replacement
Neye ihtiyacın var
  1. HTC Touch Pro CDMA Keyboard Replacement, Battery: adım 1, 2 resimden 1. HTC Touch Pro CDMA Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • First, gently press on the back plate and push down toward the camera.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Touch Pro CDMA Keyboard Replacement: adım 2, 2 resimden 1. HTC Touch Pro CDMA Keyboard Replacement: adım 2, 2 resimden 2.
    • Use your finger to lift up the edge of the battery.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Touch Pro CDMA Keyboard Replacement, USB Logic Board: adım 3, 1 resimden 1.
    • Remove the 4 screws using the T6 screw driver.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Touch Pro CDMA Keyboard Replacement: adım 4, 2 resimden 1. HTC Touch Pro CDMA Keyboard Replacement: adım 4, 2 resimden 2.
    • Lift the plastic cover near the memory card slot.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Touch Pro CDMA Keyboard Replacement: adım 5, 1 resimden 1.
    • Remove the two Phillips #00 screws from the backside of the screen.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Touch Pro CDMA Keyboard Replacement: adım 6, 2 resimden 1. HTC Touch Pro CDMA Keyboard Replacement: adım 6, 2 resimden 2.
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Touch Pro CDMA Keyboard Replacement: adım 7, 2 resimden 1. HTC Touch Pro CDMA Keyboard Replacement: adım 7, 2 resimden 2.
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. HTC Touch Pro CDMA Keyboard Replacement: adım 8, 2 resimden 1. HTC Touch Pro CDMA Keyboard Replacement: adım 8, 2 resimden 2.
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
    FixBot'a Sor
    Yorum Ekle
  9. HTC Touch Pro CDMA Keyboard Replacement, Keyboard: adım 9, 2 resimden 1. HTC Touch Pro CDMA Keyboard Replacement, Keyboard: adım 9, 2 resimden 2.
    • Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Zhaowei Zhang
133 İtibar
4 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 1-6, Nelson Spring 2011 CSU Los Angeles, Team 1-6, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G6
3 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 2,360
