Giriş
This easy to follow guide will show you in the ins and outs on how to repair your HTC Touch Pro.
  1. First, gently press on the back plate and push down toward the camera. First, gently press on the back plate and push down toward the camera.
    • First, gently press on the back plate and push down toward the camera.
  2. Use your finger to lift up the edge of the battery. Use your finger to lift up the edge of the battery.
    • Use your finger to lift up the edge of the battery.
  3. Remove the 4 screws using the T6 screw driver.
    • Remove the 4 screws using the T6 screw driver.
  4. Lift the plastic cover near the memory card slot. Lift the plastic cover near the memory card slot.
    • Lift the plastic cover near the memory card slot.
  5. Remove the two Phillips #00 screws from the backside of the screen.
    • Remove the two Phillips #00 screws from the backside of the screen.
  6. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  7. Insert a spudger or a plastic opening tool into the seam on the side of the phone. Gently pry apart the two halves of the phone.
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
  8. Gently unplug the connectors. Remove the screws with a 00 Phillips-head screwdriver.
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
  9. Gently lift the motherboard up using  a nylon spudger. BE AWARE OF THE ANTENNA.
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
  10. Remove the 4 screws circled in red using a 00 Phillips-head screwdriver. Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
    • Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
  11. Start by lifting the back plate of the screen  by using yours finger or a plastic opener tool. Start by lifting the back plate of the screen  by using yours finger or a plastic opener tool.
    • Start by lifting the back plate of the screen by using yours finger or a plastic opener tool.
  12. Remove the 4 screws by using a 00 Phillips-head screwdriver.
    • Remove the 4 screws by using a 00 Phillips-head screwdriver.
    • Gently lift the connectors.
  13. Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
    • Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
  14. With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it . With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it . With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
    • With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
Sonuç
2 başka kişi bu kılavuzu tamamladı.
Zhaowei Zhang
112 İtibar
4 adet Kılavuz yazıldı
Takım
CSU Los Angeles, Team 1-6, Nelson Spring 2011 CSU Los Angeles, Team 1-6, Nelson Spring 2011 üyesi
CSULA-NELSON-S11S1G6
3 Üyeler
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 1
Her zaman: 3,410
