Ana içeriğe geç
HTC Trophy Display Assembly Replacement
Neye ihtiyacın var
    1. HTC Trophy Display Assembly Replacement, Battery: adım 1, 3 resimden 1. HTC Trophy Display Assembly Replacement, Battery: adım 1, 3 resimden 2. HTC Trophy Display Assembly Replacement, Battery: adım 1, 3 resimden 3.
      • Power off the phone before starting.
      • Remove the back panel by inserting the IFixIt opening tool into gap at the top of the rear and prying upward.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Trophy Display Assembly Replacement: adım 2, 3 resimden 1. HTC Trophy Display Assembly Replacement: adım 2, 3 resimden 2. HTC Trophy Display Assembly Replacement: adım 2, 3 resimden 3.
      • Remove the battery by inserting the IFixIt opening tool into the small gap between the battery and the surrounding plastic.
      • Apply a small force towards the bottom of the phone and lift upwards.
      • Be careful not to puncture the battery.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Trophy Display Assembly Replacement, Display Assembly: adım 3, 3 resimden 1. HTC Trophy Display Assembly Replacement, Display Assembly: adım 3, 3 resimden 2. HTC Trophy Display Assembly Replacement, Display Assembly: adım 3, 3 resimden 3.
      • Remove the 5 screws holding the two phone halves together.
      • Three 4mm long T5 Torx screws.
      • Press a T5 Torx screwdriver into the void sticker and remove the 4mm long T5 Torx screw.
      • One 4mm long Philips #000 screw.
      • Remove the installed SIM card if one is present.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Trophy Display Assembly Replacement: adım 4, 3 resimden 1. HTC Trophy Display Assembly Replacement: adım 4, 3 resimden 2. HTC Trophy Display Assembly Replacement: adım 4, 3 resimden 3.
      • Insert the IFixIt opening tool into the seem of the plastic around the edge of the phone and pry the two halves apart.
      • There are small plastic clips holding the phone together. Slide the opening tool around the edge until it clicks apart to avoid damage.
      • The volume button will fall out when the phone is opened.
      • The black sticker beneath the battery will rip once the phone is separated.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Trophy Display Assembly Replacement: adım 5, 3 resimden 1. HTC Trophy Display Assembly Replacement: adım 5, 3 resimden 2. HTC Trophy Display Assembly Replacement: adım 5, 3 resimden 3.
      • Remove the three screws holding the mother board to the display assembly.
      • One 2mm long Philips #000 screw.
      • Two 4mm long T5 Torx screws in the holes of the plastic.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Trophy Display Assembly Replacement: adım 6, 3 resimden 1. HTC Trophy Display Assembly Replacement: adım 6, 3 resimden 2. HTC Trophy Display Assembly Replacement: adım 6, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the black tape cover the ribbon cable connectors with tweezers.
      • Disconnect the ribbon cables from the connectors.
      • Ribbon cables are extremely fragile.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Trophy Display Assembly Replacement: adım 7, 2 resimden 1. HTC Trophy Display Assembly Replacement: adım 7, 2 resimden 2.
      • Remove power button from the top of the phone with tweezers.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Trophy Display Assembly Replacement: adım 8, 3 resimden 1. HTC Trophy Display Assembly Replacement: adım 8, 3 resimden 2. HTC Trophy Display Assembly Replacement: adım 8, 3 resimden 3.
      • Use the iFixit opening tool to separate the motherboard from the display assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 395
