Ana içeriğe geç
HTC Vive Controller Battery Replacement
Neye ihtiyacın var
  1. HTC Vive Controller Battery Replacement, Saucer Panels: adım 1, 3 resimden 1. HTC Vive Controller Battery Replacement, Saucer Panels: adım 1, 3 resimden 2. HTC Vive Controller Battery Replacement, Saucer Panels: adım 1, 3 resimden 3.
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
  2. HTC Vive Controller Battery Replacement: adım 2, 2 resimden 1. HTC Vive Controller Battery Replacement: adım 2, 2 resimden 2.
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
  3. HTC Vive Controller Battery Replacement: adım 3, 2 resimden 1. HTC Vive Controller Battery Replacement: adım 3, 2 resimden 2.
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
  4. HTC Vive Controller Battery Replacement: adım 4, 3 resimden 1. HTC Vive Controller Battery Replacement: adım 4, 3 resimden 2. HTC Vive Controller Battery Replacement: adım 4, 3 resimden 3.
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
  5. HTC Vive Controller Battery Replacement, Front Panel: adım 5, 2 resimden 1. HTC Vive Controller Battery Replacement, Front Panel: adım 5, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
  6. HTC Vive Controller Battery Replacement: adım 6, 1 resimden 1.
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
  7. HTC Vive Controller Battery Replacement: adım 7, 2 resimden 1. HTC Vive Controller Battery Replacement: adım 7, 2 resimden 2.
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
  8. HTC Vive Controller Battery Replacement: adım 8, 1 resimden 1.
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
  9. HTC Vive Controller Battery Replacement: adım 9, 2 resimden 1. HTC Vive Controller Battery Replacement: adım 9, 2 resimden 2.
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
  10. HTC Vive Controller Battery Replacement: adım 10, 3 resimden 1. HTC Vive Controller Battery Replacement: adım 10, 3 resimden 2. HTC Vive Controller Battery Replacement: adım 10, 3 resimden 3.
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
  11. HTC Vive Controller Battery Replacement, Battery: adım 11, 2 resimden 1. HTC Vive Controller Battery Replacement, Battery: adım 11, 2 resimden 2.
    • Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
  12. HTC Vive Controller Battery Replacement: adım 12, 1 resimden 1.
    • Remove the silver plate by pinching it with two fingers and lifting up.
  13. HTC Vive Controller Battery Replacement: adım 13, 1 resimden 1.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
  14. HTC Vive Controller Battery Replacement: adım 14, 2 resimden 1. HTC Vive Controller Battery Replacement: adım 14, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
  15. HTC Vive Controller Battery Replacement: adım 15, 2 resimden 1. HTC Vive Controller Battery Replacement: adım 15, 2 resimden 2.
    • Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
  16. HTC Vive Controller Battery Replacement: adım 16, 3 resimden 1. HTC Vive Controller Battery Replacement: adım 16, 3 resimden 2. HTC Vive Controller Battery Replacement: adım 16, 3 resimden 3.
    • Lift the battery frame to remove the battery from the Vive controller
Sonuç
33 farklı kişi bu kılavuzu tamamladı.
Ryan Grewohl
878 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G5, Livingston Fall 2017 Cal Poly, Team S15-G5, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G5
4 Üyeler
51 adet Kılavuz yazıldı
14Kılavuz Yorumları
well if theres no parts…then theres no point…
altimmons - Yanıt
So, where do I get a replacement battery from? Does anyone know the part number?
scotty - Yanıt
This helped me ALOT. i had a controller stop charging or powering on. Decided to use this guide to pull just pull power and re seed the connection for the battery. The Battery connection IS NOT CLIPPED IN. TAPE holds down the connection to the terminals. So it can easy come loose over jolts and shocks or normal use
Mike Moutrie - Yanıt
battery is 3.85vdc 960ma
HTC model boplh100
3.69Whr
Part number 35H00244-00M
guido - Yanıt
With all the comments and steps, I easily took apart and rebuilt my controller. Thank you!!
Also, I used this cheap repair kit they sell at walmart if you dont have the tools and don't want to order them online.
https://www.walmart.com/ip/Hyper-Tough-T...
A K - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 127
Son 30 gün: 804
Her zaman: 46,022
