Ana içeriğe geç
HTC Vive Controller Front Panel Buttons Replacement
Neye ihtiyacın var
  1. HTC Vive Controller Front Panel Buttons Replacement, Saucer Panels: adım 1, 3 resimden 1. HTC Vive Controller Front Panel Buttons Replacement, Saucer Panels: adım 1, 3 resimden 2. HTC Vive Controller Front Panel Buttons Replacement, Saucer Panels: adım 1, 3 resimden 3.
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Vive Controller Front Panel Buttons Replacement: adım 2, 2 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 2, 2 resimden 2.
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Vive Controller Front Panel Buttons Replacement: adım 3, 2 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 3, 2 resimden 2.
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Vive Controller Front Panel Buttons Replacement: adım 4, 3 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 4, 3 resimden 2. HTC Vive Controller Front Panel Buttons Replacement: adım 4, 3 resimden 3.
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Vive Controller Front Panel Buttons Replacement, Front Panel: adım 5, 2 resimden 1. HTC Vive Controller Front Panel Buttons Replacement, Front Panel: adım 5, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Vive Controller Front Panel Buttons Replacement: adım 6, 1 resimden 1.
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Vive Controller Front Panel Buttons Replacement: adım 7, 2 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 7, 2 resimden 2.
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
    FixBot'a Sor
    Yorum Ekle
  8. HTC Vive Controller Front Panel Buttons Replacement: adım 8, 1 resimden 1.
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
    FixBot'a Sor
    Yorum Ekle
  9. HTC Vive Controller Front Panel Buttons Replacement: adım 9, 2 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 9, 2 resimden 2.
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
    FixBot'a Sor
    Yorum Ekle
  10. HTC Vive Controller Front Panel Buttons Replacement: adım 10, 3 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 10, 3 resimden 2. HTC Vive Controller Front Panel Buttons Replacement: adım 10, 3 resimden 3.
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
    FixBot'a Sor
    Yorum Ekle
  11. HTC Vive Controller Front Panel Buttons Replacement, Front Panel Buttons: adım 11, 3 resimden 1. HTC Vive Controller Front Panel Buttons Replacement, Front Panel Buttons: adım 11, 3 resimden 2. HTC Vive Controller Front Panel Buttons Replacement, Front Panel Buttons: adım 11, 3 resimden 3.
    • Use the T5 Torx head screwdriver to remove the two silver 4.2mm screws from rear plastic cover of the system button.
    FixBot'a Sor
    Yorum Ekle
  12. HTC Vive Controller Front Panel Buttons Replacement: adım 12, 2 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 12, 2 resimden 2.
    • Lift the plastic cover up and out of the front panel using your hand.
    FixBot'a Sor
    Yorum Ekle
  13. HTC Vive Controller Front Panel Buttons Replacement: adım 13, 2 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 13, 2 resimden 2.
    • Push the system button with your finger until it pops out of the front panel.
    FixBot'a Sor
    Yorum Ekle
  14. HTC Vive Controller Front Panel Buttons Replacement: adım 14, 3 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 14, 3 resimden 2. HTC Vive Controller Front Panel Buttons Replacement: adım 14, 3 resimden 3.
    • Use the T5 Torx head screwdriver to remove the two silver 4.2mm screws from rear portion of the trackpad.
    • Lift the trackpad up and out of the panel using your hand.
    FixBot'a Sor
    Yorum Ekle
  15. HTC Vive Controller Front Panel Buttons Replacement: adım 15, 2 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 15, 2 resimden 2.
    • Use the T5 Torx head screwdriver to remove the two silver 4.2mm screws from the rear plastic cover of the menu button.
    • You may need to fold the ribbon cable to the left in order to expose the second silver screw.
    FixBot'a Sor
    Yorum Ekle
  16. HTC Vive Controller Front Panel Buttons Replacement: adım 16, 1 resimden 1.
    • Lift the plastic cover up and out of the panel using your hand.
    FixBot'a Sor
    Yorum Ekle
  17. HTC Vive Controller Front Panel Buttons Replacement: adım 17, 2 resimden 1. HTC Vive Controller Front Panel Buttons Replacement: adım 17, 2 resimden 2.
    • Push the menu button with your finger until it pops out of the front panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Christopher Amaro
972 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G5, Livingston Fall 2017 Cal Poly, Team S15-G5, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G5
4 Üyeler
51 adet Kılavuz yazıldı
5Kılavuz Yorumları
Okay great! But where can I buy replacement parts?
Colton Hoffman - Yanıt Paylaş
Thanks for the guide! Even though iFixit doesn’t have the replacement parts, I was able to fix my button that was off-center and get my controller back up and running! The only issue is that with step 5, the T5 screwdriver that comes with the iFixit tool kits doesn’t work, as it’s too wide. I had to go out and buy a narrower driver, but still much less expensive than the controller. Thanks again!
Ryan Sandberg - Yanıt Paylaş
I had my front panel TOUCHPAD STUCK, in the sense it could sense my thumb touch, but NOT my thumb press on the upper-right part (presses on the other directions were detected). I figured out how to fix it:
The touchpad presses are detected by a little sensor on the controller: it’s the little pink button we can see on the picture of Step 8 on the dark-blue board. This button is pressed when pressing the touchpad, via a little black round plastic thingy behind the very center of the touchpad : we can see it on the top of picture of Step 11, the little black circle. If this black circle is off-center or simply *too low*, the contact with the pink button will not happen properly. I personnaly got the black circle thingy off, placed another thin layer of material below it (of approximately the size of the thingy) and placed it back, so it would be more in contact with the pink button. Solved on my both controllers !
Thanks for this really good guide which helped me solve this !
Jesuis Une - Yanıt Paylaş
Hi! My ribbon cable to the touchpad is damaged. Does anyonw know whre to buy a replacment? Seems like it’s soldered to the rumblepack also.
Andreas Andersson - Yanıt Paylaş
I replaced the little disc that Jesuis Une was talking about with a piece of PTFE used for mouse skates. The disc is 5/32 or 4.0 mm. I used a punch to knock a piece of 0.6 mm PTFE from the excess edging and it works like a charm.
Eric Tong - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 60
Her zaman: 9,601
