Ana içeriğe geç
HTC Vive Controller Grip Buttons Replacement
Neye ihtiyacın var
  1. HTC Vive Controller Grip Buttons Replacement, Saucer Panels: adım 1, 3 resimden 1. HTC Vive Controller Grip Buttons Replacement, Saucer Panels: adım 1, 3 resimden 2. HTC Vive Controller Grip Buttons Replacement, Saucer Panels: adım 1, 3 resimden 3.
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
  2. HTC Vive Controller Grip Buttons Replacement: adım 2, 2 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 2, 2 resimden 2.
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
  3. HTC Vive Controller Grip Buttons Replacement: adım 3, 2 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 3, 2 resimden 2.
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
  4. HTC Vive Controller Grip Buttons Replacement: adım 4, 3 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 4, 3 resimden 2. HTC Vive Controller Grip Buttons Replacement: adım 4, 3 resimden 3.
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
  5. HTC Vive Controller Grip Buttons Replacement, Front Panel: adım 5, 2 resimden 1. HTC Vive Controller Grip Buttons Replacement, Front Panel: adım 5, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
  6. HTC Vive Controller Grip Buttons Replacement: adım 6, 1 resimden 1.
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
  7. HTC Vive Controller Grip Buttons Replacement: adım 7, 2 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 7, 2 resimden 2.
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
  8. HTC Vive Controller Grip Buttons Replacement: adım 8, 1 resimden 1.
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
  9. HTC Vive Controller Grip Buttons Replacement: adım 9, 2 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 9, 2 resimden 2.
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
  10. HTC Vive Controller Grip Buttons Replacement: adım 10, 3 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 10, 3 resimden 2. HTC Vive Controller Grip Buttons Replacement: adım 10, 3 resimden 3.
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
  11. HTC Vive Controller Grip Buttons Replacement, Battery: adım 11, 2 resimden 1. HTC Vive Controller Grip Buttons Replacement, Battery: adım 11, 2 resimden 2.
    • Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
  12. HTC Vive Controller Grip Buttons Replacement: adım 12, 1 resimden 1.
    • Remove the silver plate by pinching it with two fingers and lifting up.
  13. HTC Vive Controller Grip Buttons Replacement: adım 13, 1 resimden 1.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
  14. HTC Vive Controller Grip Buttons Replacement: adım 14, 2 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 14, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
  15. HTC Vive Controller Grip Buttons Replacement: adım 15, 2 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 15, 2 resimden 2.
    • Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
  16. HTC Vive Controller Grip Buttons Replacement: adım 16, 3 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 16, 3 resimden 2. HTC Vive Controller Grip Buttons Replacement: adım 16, 3 resimden 3.
    • Lift the battery frame to remove the battery from the Vive controller
  17. HTC Vive Controller Grip Buttons Replacement, Motherboard: adım 17, 1 resimden 1.
    • Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the top of the motherboard.
  18. HTC Vive Controller Grip Buttons Replacement: adım 18, 2 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 18, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the motherboard.
  19. HTC Vive Controller Grip Buttons Replacement: adım 19, 3 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 19, 3 resimden 2. HTC Vive Controller Grip Buttons Replacement: adım 19, 3 resimden 3.
    • Use the nylon spudger to rotate the black tab up by 90 degrees.
    • Disconnect the ribbon cable carefully with your finger.
  20. HTC Vive Controller Grip Buttons Replacement: adım 20, 3 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 20, 3 resimden 2. HTC Vive Controller Grip Buttons Replacement: adım 20, 3 resimden 3.
    • Lift the motherboard up and out of the Vive controller using your hands.
  21. HTC Vive Controller Grip Buttons Replacement, Grip Buttons: adım 21, 1 resimden 1.
    • Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the silver rectangular plate.
  22. HTC Vive Controller Grip Buttons Replacement: adım 22, 1 resimden 1.
    • Lift the silver rectangular plate up and out of the controller using your hand.
  23. HTC Vive Controller Grip Buttons Replacement: adım 23, 3 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 23, 3 resimden 2. HTC Vive Controller Grip Buttons Replacement: adım 23, 3 resimden 3.
    • Use the nylon spudger to lift the bottom rubber tab on the inside of the right grip button.
    • Use the nylon spudger to lift the top rubber tab on the inside of the right grip button.
  24. HTC Vive Controller Grip Buttons Replacement: adım 24, 2 resimden 1. HTC Vive Controller Grip Buttons Replacement: adım 24, 2 resimden 2.
    • Push the grip button in with your finger until it pops out of its socket.
    • You may hear a popping sound when you pop out the grip button
    • Repeat steps 23 and 24 to remove the left side grip button.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Amaro
963 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G5, Livingston Fall 2017 Cal Poly, Team S15-G5, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G5
4 Üyeler
51 adet Kılavuz yazıldı
2Kılavuz Yorumları
It’s all fine and dandy but this part is nowhere to be found
olivier.ducran2 - Yanıt
Hi, first of all ty for the tools and all the effort.
During disassembly my system button's 7 contanct fpc connector ripped apart and cant find any label on it.
I am trying to find a replacement part to re-solder it.
Can you help me with a name of that connector.
Thanks
Zoltán Táborosi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 73
Her zaman: 5,372
