Ana içeriğe geç
HTC Vive Controller Saucer Replacement
Neye ihtiyacın var
  1. HTC Vive Controller Saucer Replacement, Saucer Panels: adım 1, 3 resimden 1. HTC Vive Controller Saucer Replacement, Saucer Panels: adım 1, 3 resimden 2. HTC Vive Controller Saucer Replacement, Saucer Panels: adım 1, 3 resimden 3.
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Vive Controller Saucer Replacement: adım 2, 2 resimden 1. HTC Vive Controller Saucer Replacement: adım 2, 2 resimden 2.
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Vive Controller Saucer Replacement: adım 3, 2 resimden 1. HTC Vive Controller Saucer Replacement: adım 3, 2 resimden 2.
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Vive Controller Saucer Replacement: adım 4, 3 resimden 1. HTC Vive Controller Saucer Replacement: adım 4, 3 resimden 2. HTC Vive Controller Saucer Replacement: adım 4, 3 resimden 3.
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Ryan Grewohl
893 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G5, Livingston Fall 2017 Cal Poly, Team S15-G5, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G5
4 Üyeler
51 adet Kılavuz yazıldı
3Kılavuz Yorumları
Where do you get the replacement parts?
dmitri.walker - Yanıt Paylaş
Vive dont less these parts we need to 3D print them its a Nightmare RN for business especially arcades
superseani2 - Yanıt Paylaş
My controller only has 2 screws that are different sizes than a t5 and the 3rd is completely covered up by plastic. I have the sticky button problem, halp pls
bizkidjordan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 61
Her zaman: 7,269
