Ana içeriğe geç
HTC Vive Controller Trigger Replacement
Neye ihtiyacın var
  1. HTC Vive Controller Trigger Replacement, Saucer Panels: adım 1, 3 resimden 1. HTC Vive Controller Trigger Replacement, Saucer Panels: adım 1, 3 resimden 2. HTC Vive Controller Trigger Replacement, Saucer Panels: adım 1, 3 resimden 3.
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Vive Controller Trigger Replacement: adım 2, 2 resimden 1. HTC Vive Controller Trigger Replacement: adım 2, 2 resimden 2.
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Vive Controller Trigger Replacement: adım 3, 2 resimden 1. HTC Vive Controller Trigger Replacement: adım 3, 2 resimden 2.
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Vive Controller Trigger Replacement: adım 4, 3 resimden 1. HTC Vive Controller Trigger Replacement: adım 4, 3 resimden 2. HTC Vive Controller Trigger Replacement: adım 4, 3 resimden 3.
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Vive Controller Trigger Replacement, Front Panel: adım 5, 2 resimden 1. HTC Vive Controller Trigger Replacement, Front Panel: adım 5, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the two black 5.2mm screws on the back gray panel.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Vive Controller Trigger Replacement: adım 6, 1 resimden 1.
    • Turn over the Vive controller so that the exposed bottom saucer panel is facing up.
    • Use the T5 Torx screwdriver to remove the three black 5.2mm screws.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Vive Controller Trigger Replacement: adım 7, 2 resimden 1. HTC Vive Controller Trigger Replacement: adım 7, 2 resimden 2.
    • Use the nylon spudger to separate the front panel gently by running the spudger around the edges of the handle.
    • Only separate the front panel around the edges. Do not try to completely remove the panel yet.
    • Gently lift the right side of the panel to the left.
    FixBot'a Sor
    Yorum Ekle
  8. HTC Vive Controller Trigger Replacement: adım 8, 1 resimden 1.
    • Disconnect the upper ribbon cable gently by pulling the ribbon up and away from the motherboard with two fingers.
    • Do not try to disconnect the ribbon cables from the front panel.
    FixBot'a Sor
    Yorum Ekle
  9. HTC Vive Controller Trigger Replacement: adım 9, 2 resimden 1. HTC Vive Controller Trigger Replacement: adım 9, 2 resimden 2.
    • Disconnect the middle ribbon cable gently by pulling the ribbon cable up and away from the motherboard with two fingers.
    FixBot'a Sor
    Yorum Ekle
  10. HTC Vive Controller Trigger Replacement: adım 10, 3 resimden 1. HTC Vive Controller Trigger Replacement: adım 10, 3 resimden 2. HTC Vive Controller Trigger Replacement: adım 10, 3 resimden 3.
    • Use the nylon spudger to lift the white tab by 90 degrees.
    • Disconnect the bottom ribbon cable gently by pulling the ribbon cable down with two fingers.
    FixBot'a Sor
    Yorum Ekle
  11. HTC Vive Controller Trigger Replacement, Battery: adım 11, 2 resimden 1. HTC Vive Controller Trigger Replacement, Battery: adım 11, 2 resimden 2.
    • Use the Phillips 00 screwdriver to remove two black 2.8mm screws from the silver plate.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the bottom right corner of the silver plate.
    FixBot'a Sor
    Yorum Ekle
  12. HTC Vive Controller Trigger Replacement: adım 12, 1 resimden 1.
    • Remove the silver plate by pinching it with two fingers and lifting up.
    FixBot'a Sor
    Yorum Ekle
  13. HTC Vive Controller Trigger Replacement: adım 13, 1 resimden 1.
    • Use the Phillips 00 screwdriver to remove the black 5.8mm screw from the top left of the battery frame.
    FixBot'a Sor
    Yorum Ekle
  14. HTC Vive Controller Trigger Replacement: adım 14, 2 resimden 1. HTC Vive Controller Trigger Replacement: adım 14, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the battery frame.
    FixBot'a Sor
    Yorum Ekle
  15. HTC Vive Controller Trigger Replacement: adım 15, 2 resimden 1. HTC Vive Controller Trigger Replacement: adım 15, 2 resimden 2.
    • Disconnect the three-pin cable gently by pinching the cable with two fingers and pulling up.
    FixBot'a Sor
    Yorum Ekle
  16. HTC Vive Controller Trigger Replacement: adım 16, 3 resimden 1. HTC Vive Controller Trigger Replacement: adım 16, 3 resimden 2. HTC Vive Controller Trigger Replacement: adım 16, 3 resimden 3.
    • Lift the battery frame to remove the battery from the Vive controller
    FixBot'a Sor
    Yorum Ekle
  17. HTC Vive Controller Trigger Replacement, Motherboard: adım 17, 1 resimden 1.
    • Use the Phillips 00 screwdriver to remove the two black 5.8mm screws from the top of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  18. HTC Vive Controller Trigger Replacement: adım 18, 2 resimden 1. HTC Vive Controller Trigger Replacement: adım 18, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove the two silver 4.2mm screws from the bottom of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  19. HTC Vive Controller Trigger Replacement: adım 19, 3 resimden 1. HTC Vive Controller Trigger Replacement: adım 19, 3 resimden 2. HTC Vive Controller Trigger Replacement: adım 19, 3 resimden 3.
    • Use the nylon spudger to rotate the black tab up by 90 degrees.
    • Disconnect the ribbon cable carefully with your finger.
    FixBot'a Sor
    Yorum Ekle
  20. HTC Vive Controller Trigger Replacement: adım 20, 3 resimden 1. HTC Vive Controller Trigger Replacement: adım 20, 3 resimden 2. HTC Vive Controller Trigger Replacement: adım 20, 3 resimden 3.
    • Lift the motherboard up and out of the Vive controller using your hands.
    FixBot'a Sor
    Yorum Ekle
  21. HTC Vive Controller Trigger Replacement, Trigger: adım 21, 1 resimden 1.
    • Use the T5 Torx screwdriver to remove the four black 5.2mm screws from the inner part of the trigger.
    FixBot'a Sor
    Yorum Ekle
  22. HTC Vive Controller Trigger Replacement: adım 22, 1 resimden 1.
    • Push the trigger button in with your finger until it pops out of the front panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Christopher Amaro
972 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G5, Livingston Fall 2017 Cal Poly, Team S15-G5, Livingston Fall 2017 üyesi
CPSU-LIVINGSTON-F17S15G5
4 Üyeler
51 adet Kılavuz yazıldı
2Kılavuz Yorumları
It is possible to access and replace the trigger without having to disconnect any of the cables. I have done this with 3 controllers already.
Just ignore the steps saying to disconnect the cable, move parts to the side and be careful.
Jurij Gera - Yanıt Paylaş
No disassembly fix for a broken spring: Sling a rubber band under the trigger.
Jon Johnson - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 6,830
