Giriş
Use this guide to replace the outer shell on your HTC Vive Pro 2 headset.
Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the procedure.
Power off and unplug your headset before you begin your repair.
Neye ihtiyacın var
Remove the All-In-One Cable from the cable guides along the left side of the head strap.
Use a Phillips screwdriver to remove the three 2.4 mm‑long screws securing the All-in-One cable bracket.
Lift the All-in-One cable bracket straight off the headset and remove it.
