Giriş
Follow this guide to replace the daughterboard in your HTC Vive Pro.
Power off and unplug your headset before you begin your repair.
Neye ihtiyacın var
Remove the All-In-One Cable from the cable guides along the left side of the head strap.
Peel off both front side foam pads to uncover the speaker wires.
Insert the pointed end of your spudger behind the square rubber spacer next to each headphone screw.
Gently pry the rubber spacers out of the head strap.
Use the pointed end of your spudger to pry up and disconnect both the left and right headphone speaker wires.
Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
Four 3.9 mm screws (two on each side)
Two 4.1 mm screws (one on each side)
Use your fingers to gently peel the facerest cushion off of the headset.
Partially separate the facerest and the sensor array to access the daughterboard.
Use a pair of tweezers to remove the Kapton tape covering the ZIF connector on the daughterboard.
Use the flat end of your spudger to disconnect the two press connectors from the daughterboard.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Bir başkası bu kılavuzu tamamladı.
