Giriş
Follow this guide to replace the head strap on your HTC Vive Pro.
Power off and unplug your headset before you begin your repair.
Neye ihtiyacın var
Remove the All-In-One Cable from the cable guides along the left side of the head strap.
Peel off both front side foam pads to uncover the speaker wires.
Insert the pointed end of your spudger behind the square rubber spacer next to each headphone screw.
Gently pry the rubber spacers out of the head strap.
Use the pointed end of your spudger to pry up and disconnect both the left and right headphone speaker wires.
Use a T6 Torx screwdriver to remove the two 12.1 mm screws (one on each side) securing the head strap to the headset.
Use a T5 Torx screwdriver to remove the following screws securing the head strap to the headset:
Four 3.9 mm screws (two on each side)
Two 4.1 mm screws (one on each side)
Transfer all foam pads from the old head strap to the new one.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Bir Yorum
There is a missing step. The replacement part doesn't contain anything to connect the audio wires to. You will have to remove a screw and pry up the little board that has the headphone connector on it. The spudger works well for this. Be aware that in addition to the screw, this little audio connector board is also held on with adhesive, so you will need to peel it off. The adhesive isn't too strong, so you can get it up pretty easily. When putting the audio connectors into the replacement head strap you'll want to be sure to peel off the backing on the adhesive before seating the board on it.
