Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The HTC Vive's sensor array may not track your movements even when the rest of the device appears to be functional. This guide will show you how to replace the Vive's sensor array assembly.
Neye ihtiyacın var
Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
Slide the top part of the head strap through its metal loop on the headset to remove it.
Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
Slide the right side of the head strap through its metal loop to remove it.
Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
Slide the left side of the head strap through its metal loop to remove it.
Slide the head strap along the cable, away from the Vive.
When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
Use tweezers to remove the small stickers over the four screws securing the outer shell.
Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
Remove the five 4mm Philips #00 screws holding the sensor array to the motherboard.
Remove the two 4mm Philips #00 screws holding the sensor array to the midframe.
Lift the sensor array away from the rest of the Vive until the camera cable tugs back and hold it in place.
Disconnect the camera by lifting its ribbon cable up and away from the motherboard using a pair of ESD safe tweezers.
Lift the sensor array upwards away from the motherboard to separate the array from the device fully.
3 farklı kişi bu kılavuzu tamamladı.
