Ana içeriğe geç
HTC Wizard 100 Back Case Replacement
Neye ihtiyacın var
  1. HTC Wizard 100 Back Case Replacement, Battery: adım 1, 2 resimden 1. HTC Wizard 100 Back Case Replacement, Battery: adım 1, 2 resimden 2.
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. HTC Wizard 100 Back Case Replacement: adım 2, 2 resimden 1. HTC Wizard 100 Back Case Replacement: adım 2, 2 resimden 2.
    • Pull on the plastic tab to release the battery.
  3. HTC Wizard 100 Back Case Replacement, Back Case: adım 3, 2 resimden 1. HTC Wizard 100 Back Case Replacement, Back Case: adım 3, 2 resimden 2.
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  4. HTC Wizard 100 Back Case Replacement: adım 4, 1 resimden 1.
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  5. HTC Wizard 100 Back Case Replacement: adım 5, 3 resimden 1. HTC Wizard 100 Back Case Replacement: adım 5, 3 resimden 2. HTC Wizard 100 Back Case Replacement: adım 5, 3 resimden 3.
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
Sonuç
Eric W
41 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G28
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 12
Her zaman: 808
