Ana içeriğe geç
HTC Wizard 100 Camera Replacement
Neye ihtiyacın var
    1. HTC Wizard 100 Camera Replacement, Battery: adım 1, 2 resimden 1. HTC Wizard 100 Camera Replacement, Battery: adım 1, 2 resimden 2.
      • Power the phone off.
      • Use your thumb to gently press downward and away from the camera to remove the battery cover.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Wizard 100 Camera Replacement: adım 2, 2 resimden 1. HTC Wizard 100 Camera Replacement: adım 2, 2 resimden 2.
      • Pull on the plastic tab to release the battery.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 100 Camera Replacement, Back Case: adım 3, 2 resimden 1. HTC Wizard 100 Camera Replacement, Back Case: adım 3, 2 resimden 2.
      • Use a plastic opening tool to remove the camera cover.
      • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
      • Lift the camera cover off of the phone.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Wizard 100 Camera Replacement: adım 4, 1 resimden 1.
      • Remove the stylus from the phone.
      • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
      • One of the screws might be under a sticker, which will void your warranty.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Wizard 100 Camera Replacement: adım 5, 3 resimden 1. HTC Wizard 100 Camera Replacement: adım 5, 3 resimden 2. HTC Wizard 100 Camera Replacement: adım 5, 3 resimden 3.
      • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
      • If your phone contains a memory card, you may want to remove it before proceeding with this step.
      • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
      • Lift the back case off completely.
      • The speakers might be dangling and unsecured.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 100 Camera Replacement, Camera: adım 6, 1 resimden 1.
      • Locate the camera and pry off with the plastic opening tool or spudger.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kevin Gingrich
180 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-28, Maness Fall 2011 Cal Poly, Team 20-28, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G28
4 Üyeler
63 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 1,077
