Ana içeriğe geç
HTC Wizard 200 Back Panel Replacement
Neye ihtiyacın var
  1. HTC Wizard 200 Back Panel Replacement, Battery: adım 1, 2 resimden 1. HTC Wizard 200 Back Panel Replacement, Battery: adım 1, 2 resimden 2.
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Back Panel Replacement, Back Panel: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    Satın Al
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Back Panel Replacement: adım 3, 2 resimden 1. HTC Wizard 200 Back Panel Replacement: adım 3, 2 resimden 2.
    Spudger
    $3.99
    Satın Al
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Back Panel Replacement: adım 4, 2 resimden 1. HTC Wizard 200 Back Panel Replacement: adım 4, 2 resimden 2.
    T5 Torx Screwdriver
    $5.49
    Satın Al
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Back Panel Replacement: adım 5, 3 resimden 1. HTC Wizard 200 Back Panel Replacement: adım 5, 3 resimden 2. HTC Wizard 200 Back Panel Replacement: adım 5, 3 resimden 3.
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Back Panel Replacement: adım 6, 2 resimden 1. HTC Wizard 200 Back Panel Replacement: adım 6, 2 resimden 2.
    • Once all the clips are open, remove the inner panel from the phone.
Sonuç
Kyle Champ
225 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-27, Maness Fall 2011 Cal Poly, Team 20-27, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G27
4 Üyeler
24 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 1,147
