Giriş
This guide will display how to remove and install the back panel of the HTC Wizard 200.
Neye ihtiyacın var
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Bu adımda kullanılan alet:Spudger$3.99
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Bu adımda kullanılan alet:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
