Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will display how to remove and install the back panel of the HTC Wizard 200.
Neye ihtiyacın var
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
Bu adımda kullanılan alet:T5 Torx Screwdriver$5.49
Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
