Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Bu adımda kullanılan alet:Spudger$3.99-
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Work the spudger around the edges of the camera cover until it comes off.
Bu adımda kullanılan alet:T5 Torx Screwdriver$5.49-
Remove the four 6 mm screws with the T5 Torx screwdriver.
Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
Work the tool around the edges until all the clips release.
Once all the clips are open, remove the inner panel from the phone.
