Ana içeriğe geç
HTC Wizard 200 Front Buttons Replacement
Neye ihtiyacın var
    1. HTC Wizard 200 Front Buttons Replacement, Battery: adım 1, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement, Battery: adım 1, 2 resimden 2.
      • To expose the battery, remove the outer case with your fingernail.
      • Remove the battery by pulling the black tab.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 200 Front Buttons Replacement, Back Panel: adım 2, 1 resimden 1.
      Bu adımda kullanılan alet:
      Spudger
      $3.99
      • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Wizard 200 Front Buttons Replacement: adım 3, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement: adım 3, 2 resimden 2.
      Spudger
      $3.99
      • Work the spudger around the edges of the camera cover until it comes off.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Wizard 200 Front Buttons Replacement: adım 4, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement: adım 4, 2 resimden 2.
      T5 Torx Screwdriver
      $5.49
      • Remove the four 6 mm screws with the T5 Torx screwdriver.
      • One of the screws is under the "void" sticker.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Wizard 200 Front Buttons Replacement: adım 5, 3 resimden 1. HTC Wizard 200 Front Buttons Replacement: adım 5, 3 resimden 2. HTC Wizard 200 Front Buttons Replacement: adım 5, 3 resimden 3.
      • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
      • Work the tool around the edges until all the clips release.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Wizard 200 Front Buttons Replacement: adım 6, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement: adım 6, 2 resimden 2.
      • Once all the clips are open, remove the inner panel from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 200 Front Buttons Replacement, Motherboard: adım 7, 1 resimden 1.
      Spudger
      $3.99
      • Use the spudger to pry the camera off.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Wizard 200 Front Buttons Replacement: adım 8, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement: adım 8, 2 resimden 2.
      • Using tweezers, flip the connector latch away from the motherboard.
      • Detach the flexible connection from under the connector latch.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Wizard 200 Front Buttons Replacement: adım 9, 1 resimden 1.
      • Slide the keyboard into the open position.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Wizard 200 Front Buttons Replacement: adım 10, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement: adım 10, 2 resimden 2.
      Spudger
      $3.99
      • Lift the motherboard out of the case using the spudger.
      • Expose the underside of the motherboard using your hands.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Wizard 200 Front Buttons Replacement: adım 11, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement: adım 11, 2 resimden 2.
      • Remove the flexible connection from the motherboard.
      • Caution: Removing the connection too fast may cause damage to the connection and cables.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 200 Front Buttons Replacement, Keyboard Slider: adım 12, 3 resimden 1. HTC Wizard 200 Front Buttons Replacement, Keyboard Slider: adım 12, 3 resimden 2. HTC Wizard 200 Front Buttons Replacement, Keyboard Slider: adım 12, 3 resimden 3.
      T5 Torx Screwdriver
      $5.49
      • Remove the four 5mm screws with the T5 Torx screwdriver.
      • Remove the keyboard slider from the main body.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 200 Front Buttons Replacement, Screen Cover: adım 13, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement, Screen Cover: adım 13, 2 resimden 2.
      • Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Wizard 200 Front Buttons Replacement: adım 14, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement: adım 14, 2 resimden 2.
      • Insert the plastic opening tool between the front panel and the rear panel and pry open to reach the screen.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Wizard 200 Front Buttons Replacement: adım 15, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement: adım 15, 2 resimden 2.
      • Once the rear panel is loose, lift it off of the front panel.
      • The flexible connection will pop loose.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Wizard 200 Front Buttons Replacement: adım 16, 1 resimden 1.
      • Device rotated 90 degrees CCW.
      • Remove the yellow anti-static tape.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Wizard 200 Front Buttons Replacement: adım 17, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement: adım 17, 2 resimden 2.
      • Unscrew the two 3mm phillips #0 screws from the bottom of the device that secure the rigid flex board to the screen panel.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Wizard 200 Front Buttons Replacement: adım 18, 1 resimden 1.
      • Device rotated 180 degrees CW.
      • Unscrew the two 3mm Phillips #0 screws from the top of the device that secure the rigid flex board to the screen panel.
      FixBot'a Sor
      Yorum Ekle
    7. HTC Wizard 200 Front Buttons Replacement: adım 19, 1 resimden 1.
      • Unhinge the flexible connection and use the tweezers to disconnect.
      FixBot'a Sor
      Yorum Ekle
    8. HTC Wizard 200 Front Buttons Replacement: adım 20, 1 resimden 1.
      • Now that the rigid flex board is loose, remove it from the screen.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 200 Front Buttons Replacement, LCD Screen: adım 21, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement, LCD Screen: adım 21, 2 resimden 2.
      • Simply pull out the loose screen.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 200 Front Buttons Replacement, Front Buttons: adım 22, 2 resimden 1. HTC Wizard 200 Front Buttons Replacement, Front Buttons: adım 22, 2 resimden 2.
      • Pull out the front button panel.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kyle Champ
225 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-27, Maness Fall 2011 Cal Poly, Team 20-27, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G27
4 Üyeler
144 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 895
