Ana içeriğe geç
HTC Wizard 200 Keypad Replacement
Neye ihtiyacın var
    1. HTC Wizard 200 Keypad Replacement, Battery: adım 1, 2 resimden 1. HTC Wizard 200 Keypad Replacement, Battery: adım 1, 2 resimden 2.
      • To expose the battery, remove the outer case with your fingernail.
      • Remove the battery by pulling the black tab.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 200 Keypad Replacement, Back Panel: adım 2, 1 resimden 1.
      Bu adımda kullanılan alet:
      Spudger
      $3.99
      • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Wizard 200 Keypad Replacement: adım 3, 2 resimden 1. HTC Wizard 200 Keypad Replacement: adım 3, 2 resimden 2.
      Spudger
      $3.99
      • Work the spudger around the edges of the camera cover until it comes off.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Wizard 200 Keypad Replacement: adım 4, 2 resimden 1. HTC Wizard 200 Keypad Replacement: adım 4, 2 resimden 2.
      T5 Torx Screwdriver
      $5.49
      • Remove the four 6 mm screws with the T5 Torx screwdriver.
      • One of the screws is under the "void" sticker.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Wizard 200 Keypad Replacement: adım 5, 3 resimden 1. HTC Wizard 200 Keypad Replacement: adım 5, 3 resimden 2. HTC Wizard 200 Keypad Replacement: adım 5, 3 resimden 3.
      • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
      • Work the tool around the edges until all the clips release.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Wizard 200 Keypad Replacement: adım 6, 2 resimden 1. HTC Wizard 200 Keypad Replacement: adım 6, 2 resimden 2.
      • Once all the clips are open, remove the inner panel from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 200 Keypad Replacement, Motherboard: adım 7, 1 resimden 1.
      Spudger
      $3.99
      • Use the spudger to pry the camera off.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Wizard 200 Keypad Replacement: adım 8, 2 resimden 1. HTC Wizard 200 Keypad Replacement: adım 8, 2 resimden 2.
      • Using tweezers, flip the connector latch away from the motherboard.
      • Detach the flexible connection from under the connector latch.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Wizard 200 Keypad Replacement: adım 9, 1 resimden 1.
      • Slide the keyboard into the open position.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Wizard 200 Keypad Replacement: adım 10, 2 resimden 1. HTC Wizard 200 Keypad Replacement: adım 10, 2 resimden 2.
      Spudger
      $3.99
      • Lift the motherboard out of the case using the spudger.
      • Expose the underside of the motherboard using your hands.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Wizard 200 Keypad Replacement: adım 11, 2 resimden 1. HTC Wizard 200 Keypad Replacement: adım 11, 2 resimden 2.
      • Remove the flexible connection from the motherboard.
      • Caution: Removing the connection too fast may cause damage to the connection and cables.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 200 Keypad Replacement, Keyboard Slider: adım 12, 3 resimden 1. HTC Wizard 200 Keypad Replacement, Keyboard Slider: adım 12, 3 resimden 2. HTC Wizard 200 Keypad Replacement, Keyboard Slider: adım 12, 3 resimden 3.
      T5 Torx Screwdriver
      $5.49
      • Remove the four 5mm screws with the T5 Torx screwdriver.
      • Remove the keyboard slider from the main body.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Wizard 200 Keypad Replacement, Keypad: adım 13, 2 resimden 1. HTC Wizard 200 Keypad Replacement, Keypad: adım 13, 2 resimden 2.
      • Use a screwdriver to remove eight 2mm Phillips screws that secure the keypad to the keyboard slider.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Wizard 200 Keypad Replacement: adım 14, 2 resimden 1. HTC Wizard 200 Keypad Replacement: adım 14, 2 resimden 2.
      • Use the plastic opening tool to gently lift up the keypad.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kyle Champ
225 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-27, Maness Fall 2011 Cal Poly, Team 20-27, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G27
4 Üyeler
144 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 31
Her zaman: 1,024
