Giriş
If your HTC Wizard 200 is frequently restarting, not turning on, or not transferring data, you may need to replace the motherboard. The motherboard is the control panel of the phone.
Follow the below steps to replace your HTC Wizard 200 motherboard.
Note: The motherboard is a very delicate structure and must be handled with care.
Neye ihtiyacın var
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Bu adımda kullanılan alet:Spudger$3.99
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Bu adımda kullanılan alet:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
Use the spudger to pry the camera off.
