Ana içeriğe geç
HTC Wizard 200 Screen Cover Replacement
Neye ihtiyacın var
  1. HTC Wizard 200 Screen Cover Replacement, Battery: adım 1, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement, Battery: adım 1, 2 resimden 2.
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Screen Cover Replacement, Back Panel: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Screen Cover Replacement: adım 3, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement: adım 3, 2 resimden 2.
    Spudger
    $3.99
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Screen Cover Replacement: adım 4, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement: adım 4, 2 resimden 2.
    T5 Torx Screwdriver
    $5.49
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Screen Cover Replacement: adım 5, 3 resimden 1. HTC Wizard 200 Screen Cover Replacement: adım 5, 3 resimden 2. HTC Wizard 200 Screen Cover Replacement: adım 5, 3 resimden 3.
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Screen Cover Replacement: adım 6, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement: adım 6, 2 resimden 2.
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Screen Cover Replacement, Motherboard: adım 7, 1 resimden 1.
    Spudger
    $3.99
    • Use the spudger to pry the camera off.
  8. HTC Wizard 200 Screen Cover Replacement: adım 8, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement: adım 8, 2 resimden 2.
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
  9. HTC Wizard 200 Screen Cover Replacement: adım 9, 1 resimden 1.
    • Slide the keyboard into the open position.
  10. HTC Wizard 200 Screen Cover Replacement: adım 10, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement: adım 10, 2 resimden 2.
    Spudger
    $3.99
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
  11. HTC Wizard 200 Screen Cover Replacement: adım 11, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement: adım 11, 2 resimden 2.
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
  12. HTC Wizard 200 Screen Cover Replacement, Keyboard Slider: adım 12, 3 resimden 1. HTC Wizard 200 Screen Cover Replacement, Keyboard Slider: adım 12, 3 resimden 2. HTC Wizard 200 Screen Cover Replacement, Keyboard Slider: adım 12, 3 resimden 3.
    T5 Torx Screwdriver
    $5.49
    • Remove the four 5mm screws with the T5 Torx screwdriver.
    • Remove the keyboard slider from the main body.
  13. HTC Wizard 200 Screen Cover Replacement, Screen Cover: adım 13, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement, Screen Cover: adım 13, 2 resimden 2.
    • Use the T5 Torx screwdriver to remove four 5mm screws that secure the back of the screen casing.
  14. HTC Wizard 200 Screen Cover Replacement: adım 14, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement: adım 14, 2 resimden 2.
    • Insert the plastic opening tool between the front panel and the rear panel and pry open to reach the screen.
  15. HTC Wizard 200 Screen Cover Replacement: adım 15, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement: adım 15, 2 resimden 2.
    • Once the rear panel is loose, lift it off of the front panel.
    • The flexible connection will pop loose.
  16. HTC Wizard 200 Screen Cover Replacement: adım 16, 1 resimden 1.
    • Device rotated 90 degrees CCW.
    • Remove the yellow anti-static tape.
  17. HTC Wizard 200 Screen Cover Replacement: adım 17, 2 resimden 1. HTC Wizard 200 Screen Cover Replacement: adım 17, 2 resimden 2.
    • Unscrew the two 3mm phillips #0 screws from the bottom of the device that secure the rigid flex board to the screen panel.
  18. HTC Wizard 200 Screen Cover Replacement: adım 18, 1 resimden 1.
    • Device rotated 180 degrees CW.
    • Unscrew the two 3mm phillips #0 screws from the top of the device that secure the rigid flex board to the screen panel.
  19. HTC Wizard 200 Screen Cover Replacement: adım 19, 1 resimden 1.
    • Unhinge the flexible connection and use the tweezers to disconnect.
  20. HTC Wizard 200 Screen Cover Replacement: adım 20, 1 resimden 1.
    • Now that the rigid flex board is loose, remove it from the screen.
Sonuç
Kyle Champ
225 İtibar
12 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-27, Maness Fall 2011 Cal Poly, Team 20-27, Maness Fall 2011 üyesi
CPSU-MANESS-F11S20G27
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 825
