Ana içeriğe geç
Giriş
This guide describes the steps to separate the HTC myTouch motherboard from the glass screen for replacement or repair. This guide will require you to unscrew a T5 Torx screw with a VOID label. Unfastening this screw would void any warranty the phone may have.
  1. Press each thumb on both sides of the upper corners and apply pressure downwards. Then, while still applying pressure, slide the back cover down.
    • Press each thumb on both sides of the upper corners and apply pressure downwards.
    • Then, while still applying pressure, slide the back cover down.
  2. Remove the Battery. Remove the SIM card.
    • Remove the Battery.
    • Remove the SIM card.
  3. Push the SD card in and the SD card should pop loose.
    • Push the SD card in and the SD card should pop loose.
    • Pull the SD card out.
  4. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Remove the four 6-mm T5 torx screws in the four corners. Remove the two 4-mm T5 torx screws in the middle.
    • Remove the four 6-mm T5 torx screws in the four corners.
    • Remove the two 4-mm T5 torx screws in the middle.
  6. Use the existing gap, to dislodge the antenna cover from the phone. Pull out the antenna cover to have access to the motherboard.
    • Use the existing gap, to dislodge the antenna cover from the phone.
    • Pull out the antenna cover to have access to the motherboard.
  7. Use a precision flathead screwdriver to dislodge the back plate from the phone by carefully inserting it into the slit between the frame and cover and pushing downward. Go around the edges of the phone, and continue to dislodge the back plate from the front part of the phone.
    • Use a precision flathead screwdriver to dislodge the back plate from the phone by carefully inserting it into the slit between the frame and cover and pushing downward.
    • Go around the edges of the phone, and continue to dislodge the back plate from the front part of the phone.
  8. Remove the 3-mm Phillips head screw located on the side of the bottom left-hand corner of the phone. Remove the 3-mm Phillips head screw located on the top right-hand corner of the phone.
    • Remove the 3-mm Phillips head screw located on the side of the bottom left-hand corner of the phone.
    • Remove the 3-mm Phillips head screw located on the top right-hand corner of the phone.
    • Do not remove any of the screws located on the actual circuit boards.
  9. Place a finger between the circuit board and the front cover, and lift up gently. Continue separating the circuit board from the front cover and screen and watch for a ribbon cable to detach. Finish separating the circuit board from the front panel.
    • Place a finger between the circuit board and the front cover, and lift up gently.
    • Continue separating the circuit board from the front cover and screen and watch for a ribbon cable to detach.
    • Finish separating the circuit board from the front panel.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Tony Tran
366 İtibar
3 adet Kılavuz yazıldı
Takım
Cal Poly, Team 2-9, Propen Fall 2012 Cal Poly, Team 2-9, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S2G9
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 1,312
