Ana içeriğe geç
HUAWEI HONOR 5X Fingerprint Scanner Replacement
Neye ihtiyacın var
  1. HUAWEI HONOR 5X Fingerprint Scanner Replacement, HUAWEI HONOR 5X Disassembly: adım 1, 1 resimden 1.
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 2, 1 resimden 1.
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 3, 2 resimden 1. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 3, 2 resimden 2.
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 4, 1 resimden 1.
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 5, 2 resimden 1. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 5, 2 resimden 2.
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Fingerprint Scanner Replacement, Motherboard: adım 6, 2 resimden 1. HUAWEI HONOR 5X Fingerprint Scanner Replacement, Motherboard: adım 6, 2 resimden 2.
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  7. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 7, 2 resimden 1. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 7, 2 resimden 2.
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  8. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 8, 3 resimden 1. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 8, 3 resimden 2. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 8, 3 resimden 3.
    • Remove the motherboard.
  9. HUAWEI HONOR 5X Fingerprint Scanner Replacement, Fingerprint Scanner: adım 9, 1 resimden 1.
    • Pull the fingerprint scanner out of its housing.
  10. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 10, 2 resimden 1. HUAWEI HONOR 5X Fingerprint Scanner Replacement: adım 10, 2 resimden 2.
    • This is what the mother board should look like when the fingerprint scanner is pulled out.
    • To fix the fingerprint scanner simply add in a new one and attach the metal component to its coordinating place.
Sonuç
Klara Asllani
788 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G6, Passmore Spring 2018 USF Tampa, Team S7-G6, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G6
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 363
