Giriş
The vibration motor is the component in a mobile device that causes the device to vibrate. If your device is not vibrating when you receive a notification, you should consider replacing the vibration motor in your device. Use this guide to replace the vibration motor in your device.
Neye ihtiyacın var
Using the metal spudger, pry the adhered vibration monitor to remove.
Neredeyse bitti!
Sonuç
