Ana içeriğe geç
HVAC Filter Replacement
Neye ihtiyacın var
  1. HVAC Filter Replacement, Filter: adım 1, 1 resimden 1.
    • Observe your air conditioning vent. If the filter appears to be dirty or damaged, then it is time to change it.
    FixBot'a Sor
    Yorum Ekle
  2. HVAC Filter Replacement: adım 2, 1 resimden 1.
    • Remove the screws on the vent cover. There should be a minimum of 4 screws in each corner of the vent.
    • The screws in this vent are phillips hex head screws that are 1 3/4 in. long.
    FixBot'a Sor
    Yorum Ekle
  3. HVAC Filter Replacement: adım 3, 1 resimden 1.
    • Grab a screwdriver with a hex head attachment to remove the screws. Grab the screwdriver and place it on the head of the screw. Twist in a counterclockwise motion until the screw is removed. Repeat for every screw.
    FixBot'a Sor
    Yorum Ekle
  4. HVAC Filter Replacement: adım 4, 1 resimden 1.
    • Remove the vent cover to access the ventilation filter.
    FixBot'a Sor
    Yorum Ekle
  5. HVAC Filter Replacement: adım 5, 1 resimden 1.
    • Optional: Put on a latex glove on the hand that you will use to remove the filter.
    FixBot'a Sor
    Yorum Ekle
  6. HVAC Filter Replacement: adım 6, 1 resimden 1.
    • Remove the filter carefully.
    • Make sure to remove it slowly so that the dust does not come of it.
    FixBot'a Sor
    Yorum Ekle
  7. HVAC Filter Replacement: adım 7, 1 resimden 1.
    • Dispose of the old filter in a waste bin.
    FixBot'a Sor
    Yorum Ekle
  8. HVAC Filter Replacement: adım 8, 1 resimden 1.
    • Buy a Honeywell Air Filter from Home Depot and make sure to buy the filter with the correct dimensions.
    • The dimensions for filters will vary depending on the dimensions of the vent.
    • In this case, my vent was 14x25x1 and thus needed a filter with the same dimensions.
    FixBot'a Sor
    Yorum Ekle
  9. HVAC Filter Replacement: adım 9, 1 resimden 1.
    • Place the new filter into the vent opening. Make sure that it is facing the right direction.
    • There will be an arrow on the side of the filter showing which way to place it.
    FixBot'a Sor
    Yorum Ekle
  10. HVAC Filter Replacement: adım 10, 1 resimden 1.
    • Place vent cover.
    FixBot'a Sor
    Yorum Ekle
  11. HVAC Filter Replacement: adım 11, 1 resimden 1.
    • Grab the same screws that were taken out at Step 3 and use them to secure the vent cover.
    • Place the screwdriver on the head of the screw and twist in a clockwise motion until screw is secure.
    • Repeat for every screw.
    FixBot'a Sor
    Yorum Ekle
  12. HVAC Filter Replacement: adım 12, 1 resimden 1.
    • Turn on your air conditioner to make sure the filter does not move.
    • If the filter does not move, then you have successfully replaced the filter of your air conditioner.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Anthony Estevez
67 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 2-1, Briggs Fall 2023 CSU Los Angeles, Team 2-1, Briggs Fall 2023 üyesi
CSULA-BRIGGS-F23S2G1
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 75
Her zaman: 839
