Ana içeriğe geç
Hair Dryer Button Switchboard Replacement
Neye ihtiyacın var
    1. Hair Dryer Button Switchboard Replacement, Nozzle: adım 1, 2 resimden 1. Hair Dryer Button Switchboard Replacement, Nozzle: adım 1, 2 resimden 2.
      • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
      • If nozzle is not attached, skip to next step.
      FixBot'a Sor
      Yorum Ekle
    1. Hair Dryer Button Switchboard Replacement, Grating: adım 2, 1 resimden 1.
      • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
      • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Hair Dryer Button Switchboard Replacement: adım 3, 1 resimden 1.
      • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
      FixBot'a Sor
      Yorum Ekle
    3. Hair Dryer Button Switchboard Replacement: adım 4, 1 resimden 1.
      • Separate the hair dryer grating into the three pieces seen in the image.
      FixBot'a Sor
      Yorum Ekle
    1. Hair Dryer Button Switchboard Replacement, Button Switchboard: adım 5, 1 resimden 1.
      • Using a Phillips #1 Screwdriver, remove the screws located on the hair dryer handle.
      FixBot'a Sor
      Yorum Ekle
    2. Hair Dryer Button Switchboard Replacement: adım 6, 1 resimden 1.
      FixBot'a Sor
      Yorum Ekle
    3. Hair Dryer Button Switchboard Replacement: adım 7, 1 resimden 1.
      • The hairdryer is now disassembled. The fan, motor, heating element cover, and internal wiring are exposed.
      • Please be careful around these parts of the hairdryer. Even if the device is off, they may be warm to the touch.
      • This is the TURBO button.
      • This is the SWITCHBOARD button.
      FixBot'a Sor
      Yorum Ekle
    4. Hair Dryer Button Switchboard Replacement: adım 8, 1 resimden 1.
      • Gently pull the turbo button away from the hair dryer body.
      • If the turbo setting is still not working after you replace the switchboard, consider using soldering techniques to replace the turbo button. It may be why the hairdryer is not working properly, too.
      FixBot'a Sor
      Yorum Ekle
    5. Hair Dryer Button Switchboard Replacement: adım 9, 1 resimden 1.
      • Gently pull the button switchboard away from the hair dryer body.
      • Using a desoldering wick and a soldering iron, desolder the wires. This will help with the electrical connection issues that may be occurring.
      • Refer to the following page for desoldering instructions: Soldering Skills
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mitch
37 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-29, Regan Fall 2012 Cal Poly, Team 24-29, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G29
5 Üyeler
70 adet Kılavuz yazıldı
1Rehber Yorum
I have a hairdryer with loose wire. Can you help me to find where the wire should be welded?
ziad musa - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 29
Son 30 gün: 91
Her zaman: 10,376
