Ana içeriğe geç
Hair Dryer Fan/ Motor Assembly Replacement
Neye ihtiyacın var
  1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: adım 1, 2 resimden 1. Hair Dryer Fan/ Motor Assembly Replacement, Nozzle: adım 1, 2 resimden 2.
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
    FixBot'a Sor
    Yorum Ekle
  2. Hair Dryer Fan/ Motor Assembly Replacement, Grating: adım 2, 1 resimden 1.
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Hair Dryer Fan/ Motor Assembly Replacement: adım 3, 1 resimden 1.
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
    FixBot'a Sor
    Yorum Ekle
  4. Hair Dryer Fan/ Motor Assembly Replacement: adım 4, 1 resimden 1.
    • Separate the hair dryer grating into the three pieces seen in the image.
    FixBot'a Sor
    Yorum Ekle
  5. Hair Dryer Fan/ Motor Assembly Replacement, Fan/ Motor Assembly: adım 5, 1 resimden 1.
    • Locate the screws on the handle and remove with a Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. Hair Dryer Fan/ Motor Assembly Replacement: adım 6, 1 resimden 1.
    • Carefully separate the plastic case with the Plastic Opening Tool.
    FixBot'a Sor
    Yorum Ekle
  7. Hair Dryer Fan/ Motor Assembly Replacement: adım 7, 1 resimden 1.
    • After removing the plastic case, locate the fan towards the back of the hair dryer.
    FixBot'a Sor
    Yorum Ekle
  8. Hair Dryer Fan/ Motor Assembly Replacement: adım 8, 1 resimden 1.
    • Remove the screw that is holding the fan to the motor using a Phillips screwdriver.
    FixBot'a Sor
    Yorum Ekle
  9. Hair Dryer Fan/ Motor Assembly Replacement: adım 9, 1 resimden 1.
    • Remove the screws holding the motor to the casing using a Phillips screwdriver.
    • NOTE: This may be unnecessary if the fan can be removed without using a screwdriver.
    FixBot'a Sor
    Yorum Ekle
  10. Hair Dryer Fan/ Motor Assembly Replacement: adım 10, 1 resimden 1.
    • Isolate the fan from the rest of the dryer.
    • Remove the screws holding the motor in place. Replace with the new component.
    FixBot'a Sor
    Yorum Ekle
  11. Hair Dryer Fan/ Motor Assembly Replacement: adım 11, 1 resimden 1.
    • Solder the wires to the motor. Refer to the soldering page below, which will help you replace this component.
    • Soldering Skills
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Mitch
37 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-29, Regan Fall 2012 Cal Poly, Team 24-29, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G29
5 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 130
Her zaman: 18,212
