Ana içeriğe geç
Hair Dryer Grating Replacement
Neye ihtiyacın var
  1. Hair Dryer Grating Replacement, Nozzle: adım 1, 2 resimden 1. Hair Dryer Grating Replacement, Nozzle: adım 1, 2 resimden 2.
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Grating Replacement, Grating: adım 2, 1 resimden 1.
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Grating Replacement: adım 3, 1 resimden 1.
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Grating Replacement: adım 4, 1 resimden 1.
    • Separate the hair dryer grating into the three pieces seen in the image.
Sonuç
Mitch
34 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-29, Regan Fall 2012 Cal Poly, Team 24-29, Regan Fall 2012 üyesi
CPSU-REGAN-F12S24G29
5 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 2,599
