Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
Detach the hair dryer grating from the body by gently twisting the grating from side to side.
Separate the hair dryer grating into the three pieces seen in the image.
Locate the screws on the handle and remove with a Phillips screwdriver
Carefully separate the plastic case with Plastic Opening Tools
Your hairdryer should now be disassembled and you should easily be able to see the fan, motor, heating element cover, and internal wiring.
After disassembly and isolating the button switchboard, locate the small component that is directly connected to the power cord. Desolder the wires using a desoldering wick and a soldering iron. Refer to the soldering page below.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Will this work on damaged cord near the end of hair dryer? The hair dryer is great shape just the cord that needed to be stripped to get rid of damaged part then cut then wired again.
