Ana içeriğe geç
Hamilton Beach 51101BA Blades Replacement
Neye ihtiyacın var
    1. Hamilton Beach 51101BA Blades Replacement, Blades: adım 1, 1 resimden 1.
      • Remove the lid from the container by holding the base and pulling up on the lid.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 51101BA Blades Replacement: adım 2, 3 resimden 1. Hamilton Beach 51101BA Blades Replacement: adım 2, 3 resimden 2. Hamilton Beach 51101BA Blades Replacement: adım 2, 3 resimden 3.
      • Remove the container from the blender.
      • Hold the blender and the container, then twist the container in a clockwise motion.
      • Make sure to follow the lock and unlock markings on the container.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 51101BA Blades Replacement: adım 3, 3 resimden 1. Hamilton Beach 51101BA Blades Replacement: adım 3, 3 resimden 2. Hamilton Beach 51101BA Blades Replacement: adım 3, 3 resimden 3.
      • Avoid placing your fingers on the blade, as they could be sharp.
      • Using a pair of pliers to hold the blade in place, use your other hand to unscrew the rubber piece on the bottom of the container.
      • Remove the rubber piece and the two washers by rotating the rubber piece counter-clockwise.
      FixBot'a Sor
      Yorum Ekle
    4. Hamilton Beach 51101BA Blades Replacement: adım 4, 1 resimden 1.
      • Carefully, pull the blades out of the container as they are very sharp.
      • Using the pliers, remove blades and the washer around the blade shaft.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device with the new blade assembly, follow these instructions in reverse order.
7 farklı kişi bu kılavuzu tamamladı.
Brandon Nunez
301 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G5
4 Üyeler
20 adet Kılavuz yazıldı
3Kılavuz Yorumları
Need to know how to install parts and how many
papi3701@aol.com - Yanıt Paylaş
Looks like I missed parts need to know the order son cuantaty
For my 501101B blender, the whole blade assembly popped out, so the blended smoothie draws at the bottom like a water falls How to fix this?
Joyful Joy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 47
Son 30 gün: 181
Her zaman: 14,209
