Ana içeriğe geç
Hamilton Beach 51101BA Blades Replacement
Neye ihtiyacın var
  1. Hamilton Beach 51101BA Blades Replacement, Blades: adım 1, 1 resimden 1.
    • Remove the lid from the container by holding the base and pulling up on the lid.
  2. Hamilton Beach 51101BA Blades Replacement: adım 2, 3 resimden 1. Hamilton Beach 51101BA Blades Replacement: adım 2, 3 resimden 2. Hamilton Beach 51101BA Blades Replacement: adım 2, 3 resimden 3.
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  3. Hamilton Beach 51101BA Blades Replacement: adım 3, 3 resimden 1. Hamilton Beach 51101BA Blades Replacement: adım 3, 3 resimden 2. Hamilton Beach 51101BA Blades Replacement: adım 3, 3 resimden 3.
    • Avoid placing your fingers on the blade, as they could be sharp.
    • Using a pair of pliers to hold the blade in place, use your other hand to unscrew the rubber piece on the bottom of the container.
    • Remove the rubber piece and the two washers by rotating the rubber piece counter-clockwise.
  4. Hamilton Beach 51101BA Blades Replacement: adım 4, 1 resimden 1.
    • Carefully, pull the blades out of the container as they are very sharp.
    • Using the pliers, remove blades and the washer around the blade shaft.
Sonuç
To reassemble your device with the new blade assembly, follow these instructions in reverse order.
6 farklı kişi bu kılavuzu tamamladı.
Brandon Nunez
283 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G5
4 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
Need to know how to install parts and how many
papi3701@aol.com - Yanıt
Looks like I missed parts need to know the order son cuantaty
For my 501101B blender, the whole blade assembly popped out, so the blended smoothie draws at the bottom like a water falls How to fix this?
Joyful Joy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 116
Her zaman: 11,736
