Ana içeriğe geç
Hamilton Beach 51101BA Motor Replacement
Neye ihtiyacın var
    1. Hamilton Beach 51101BA Motor Replacement, Rotor: adım 1, 3 resimden 1. Hamilton Beach 51101BA Motor Replacement, Rotor: adım 1, 3 resimden 2. Hamilton Beach 51101BA Motor Replacement, Rotor: adım 1, 3 resimden 3.
      • Remove the container from the blender.
      • Hold the blender and the container, then twist the container in a clockwise motion.
      • Make sure to follow the lock and unlock markings on the container.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 51101BA Motor Replacement: adım 2, 1 resimden 1.
      • Turn the blender so the bottom is facing you.
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 51101BA Motor Replacement: adım 3, 1 resimden 1.
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
      FixBot'a Sor
      Yorum Ekle
    4. Hamilton Beach 51101BA Motor Replacement: adım 4, 1 resimden 1.
      • Unhinge the plastic motor platform from the blender.
      • You may need a plastic spudger to unhinge the motor platform from the blender.
      FixBot'a Sor
      Yorum Ekle
    5. Hamilton Beach 51101BA Motor Replacement: adım 5, 2 resimden 1. Hamilton Beach 51101BA Motor Replacement: adım 5, 2 resimden 2.
      • Using a spudger, carefully insert the tip into the coil of wire around motor.
      • This is used to hold the rotating piece of the motor still.
      FixBot'a Sor
      Yorum Ekle
    6. Hamilton Beach 51101BA Motor Replacement: adım 6, 1 resimden 1.
      • Remove the white rotor piece by rotating it counter-clockwise.
      • While rotating, make sure the rotating piece of the motor remains still.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 51101BA Motor Replacement, Motor: adım 7, 2 resimden 1. Hamilton Beach 51101BA Motor Replacement, Motor: adım 7, 2 resimden 2.
      • Move the motor platform to the side.
      • Lift up the motor and remove it from the blender.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 51101BA Motor Replacement: adım 8, 1 resimden 1.
      • Some soldering experience required!
      • Desolder the red wire from the green plastic piece.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 51101BA Motor Replacement: adım 9, 1 resimden 1.
      • Cut the thin black wire from the wire cap.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Huff
616 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G5
4 Üyeler
13 adet Kılavuz yazıldı
2Kılavuz Yorumları
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Geo Jack Jack - Yanıt Paylaş
Que tipo de motor tengo que comprar?
hugoalex521 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 25
Son 30 gün: 91
Her zaman: 8,927
