Ana içeriğe geç
Hamilton Beach 51101BA Motor Replacement
Neye ihtiyacın var
  1. Hamilton Beach 51101BA Motor Replacement, Rotor: adım 1, 3 resimden 1. Hamilton Beach 51101BA Motor Replacement, Rotor: adım 1, 3 resimden 2. Hamilton Beach 51101BA Motor Replacement, Rotor: adım 1, 3 resimden 3.
    • Remove the container from the blender.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Motor Replacement: adım 2, 1 resimden 1.
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Motor Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
  4. Hamilton Beach 51101BA Motor Replacement: adım 4, 1 resimden 1.
    • Unhinge the plastic motor platform from the blender.
    • You may need a plastic spudger to unhinge the motor platform from the blender.
  5. Hamilton Beach 51101BA Motor Replacement: adım 5, 2 resimden 1. Hamilton Beach 51101BA Motor Replacement: adım 5, 2 resimden 2.
    • Using a spudger, carefully insert the tip into the coil of wire around motor.
    • This is used to hold the rotating piece of the motor still.
  6. Hamilton Beach 51101BA Motor Replacement: adım 6, 1 resimden 1.
    • Remove the white rotor piece by rotating it counter-clockwise.
    • While rotating, make sure the rotating piece of the motor remains still.
  7. Hamilton Beach 51101BA Motor Replacement, Motor: adım 7, 2 resimden 1. Hamilton Beach 51101BA Motor Replacement, Motor: adım 7, 2 resimden 2.
    • Move the motor platform to the side.
    • Lift up the motor and remove it from the blender.
  8. Hamilton Beach 51101BA Motor Replacement: adım 8, 1 resimden 1.
    • Some soldering experience required!
    • Desolder the red wire from the green plastic piece.
  9. Hamilton Beach 51101BA Motor Replacement: adım 9, 1 resimden 1.
    • Cut the thin black wire from the wire cap.
Sonuç
Andrew Huff
568 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G5
4 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
This article appears to be unfinished. You cut 2 wires at the end... then what? Reconnecting them doesn't make any sense.
Geo Jack Jack - Yanıt
Que tipo de motor tengo que comprar?
hugoalex521 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 78
Her zaman: 6,968
