Ana içeriğe geç
Hamilton Beach 51101BA Power Button Replacement
Neye ihtiyacın var
    1. Hamilton Beach 51101BA Power Button Replacement, Power Button: adım 1, 3 resimden 1. Hamilton Beach 51101BA Power Button Replacement, Power Button: adım 1, 3 resimden 2. Hamilton Beach 51101BA Power Button Replacement, Power Button: adım 1, 3 resimden 3.
      • Remove the container from the base.
      • Hold the blender and the container, then twist the container in a clockwise motion.
      • Make sure to follow the lock and unlock markings on the container.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 51101BA Power Button Replacement: adım 2, 1 resimden 1.
      • Turn the blender so the bottom is facing you.
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 51101BA Power Button Replacement: adım 3, 1 resimden 1.
      • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the motor platform.
      FixBot'a Sor
      Yorum Ekle
    4. Hamilton Beach 51101BA Power Button Replacement: adım 4, 2 resimden 1. Hamilton Beach 51101BA Power Button Replacement: adım 4, 2 resimden 2.
      • Unhinge the motor platform from the blender.
      • You may need a plastic spudger to unhinge the plastic bottom piece from the base of the blender.
      • You do not need to completely remove this piece from the base.
      FixBot'a Sor
      Yorum Ekle
    5. Hamilton Beach 51101BA Power Button Replacement: adım 5, 1 resimden 1.
      • Pull out the rectangular green piece.
      • This is the actual power button.
      FixBot'a Sor
      Yorum Ekle
    6. Hamilton Beach 51101BA Power Button Replacement: adım 6, 1 resimden 1.
      • Some experience in soldering is required!
      • On the back of the power button, desolder the red and grey wires that are connected to the piece.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Brandon Nunez
301 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G5
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 30
Her zaman: 4,050
