Ana içeriğe geç
Hamilton Beach 51101BA Power Cord Replacement
Neye ihtiyacın var
  1. Hamilton Beach 51101BA Power Cord Replacement, Power Cord: adım 1, 3 resimden 1. Hamilton Beach 51101BA Power Cord Replacement, Power Cord: adım 1, 3 resimden 2. Hamilton Beach 51101BA Power Cord Replacement, Power Cord: adım 1, 3 resimden 3.
    • Remove container from base.
    • Hold the blender and the container, then twist the container in a clockwise motion.
    • Make sure to follow the lock and unlock markings on the container.
  2. Hamilton Beach 51101BA Power Cord Replacement: adım 2, 1 resimden 1.
    • Turn the blender so the bottom is facing you.
    • Using a Phillips #2 screwdriver, remove the two 5 mm Phillips screws from the base.
  3. Hamilton Beach 51101BA Power Cord Replacement: adım 3, 1 resimden 1.
    • Lift the two wires from the motor platform.
  4. Hamilton Beach 51101BA Power Cord Replacement: adım 4, 1 resimden 1.
    • Using the wire cutters, cut the end of the thick black wires.
Sonuç
To reassemble your device, you must solder the new power cord to the thin black and thin gray wires, and follow the steps in reverse order. Requires soldering skills.
Bir başkası bu kılavuzu tamamladı.
Andrew Huff
568 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-5, Sullivan Fall 2015 USF Tampa, Team 2-5, Sullivan Fall 2015 üyesi
USFT-SULLIVAN-F15S2G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 26
Her zaman: 1,982
