Ana içeriğe geç
Hamilton Beach 70730 Drive Shaft Replacement
Neye ihtiyacın var
  1. Hamilton Beach 70730 Drive Shaft Replacement, Bowl: adım 1, 1 resimden 1.
    • Unscrew the cover by turning it counterclockwise.
  2. Hamilton Beach 70730 Drive Shaft Replacement: adım 2, 1 resimden 1.
    • Grab the scraper by the midsection to remove.
  3. Hamilton Beach 70730 Drive Shaft Replacement: adım 3, 1 resimden 1.
    • Carefully remove the blades by lifting them off of the blade shaft.
  4. Hamilton Beach 70730 Drive Shaft Replacement: adım 4, 1 resimden 1.
    • Rotate the bowl counterclockwise to release it from the base.
  5. Hamilton Beach 70730 Drive Shaft Replacement: adım 5, 1 resimden 1.
    • Make sure there is no food or grime along the outside of the bowl or the base.
  6. Hamilton Beach 70730 Drive Shaft Replacement, Drive Shaft: adım 6, 1 resimden 1.
    • Using the metal spudger, remove the four adhesive plastic covers that hide the screws.
    • These covers are adhered to the screws.
  7. Hamilton Beach 70730 Drive Shaft Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove any excess glue that is adhered to the screws with the precision tweezers.
  8. Hamilton Beach 70730 Drive Shaft Replacement: adım 8, 1 resimden 1.
    • Using a JIS #1 driver, remove the four 10 mm screws.
  9. Hamilton Beach 70730 Drive Shaft Replacement: adım 9, 1 resimden 1.
    • Lift the driveshaft off of the base.
Sonuç
Mack Bernard
597 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Isaacson Spring 2016 UMass Dartmouth, Team 2-4, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,160
