Ana içeriğe geç
Hamilton Beach 70730 Motor Replacement
Neye ihtiyacın var
  1. Hamilton Beach 70730 Motor Replacement, Bowl: adım 1, 1 resimden 1.
    • Unscrew the cover by turning it counterclockwise.
  2. Hamilton Beach 70730 Motor Replacement: adım 2, 1 resimden 1.
    • Grab the scraper by the midsection to remove.
  3. Hamilton Beach 70730 Motor Replacement: adım 3, 1 resimden 1.
    • Carefully remove the blades by lifting them off of the blade shaft.
  4. Hamilton Beach 70730 Motor Replacement: adım 4, 1 resimden 1.
    • Rotate the bowl counterclockwise to release it from the base.
  5. Hamilton Beach 70730 Motor Replacement: adım 5, 1 resimden 1.
    • Make sure there is no food or grime along the outside of the bowl or the base.
  6. Hamilton Beach 70730 Motor Replacement, Switch: adım 6, 1 resimden 1.
    • Using a metal spudger, pry the switch from the front of the device.
  7. Hamilton Beach 70730 Motor Replacement, Drive Shaft: adım 7, 1 resimden 1.
    • Using the metal spudger, remove the four adhesive plastic covers that hide the screws.
    • These covers are adhered to the screws.
  8. Hamilton Beach 70730 Motor Replacement: adım 8, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Remove any excess glue that is adhered to the screws with the precision tweezers.
  9. Hamilton Beach 70730 Motor Replacement: adım 9, 1 resimden 1.
    • Using a JIS #1 driver, remove the four 10 mm screws.
  10. Hamilton Beach 70730 Motor Replacement: adım 10, 1 resimden 1.
    • Lift the driveshaft off of the base.
  11. Hamilton Beach 70730 Motor Replacement, Motor: adım 11, 1 resimden 1.
    • Reach in and remove the set of 3 gears.
  12. Hamilton Beach 70730 Motor Replacement: adım 12, 1 resimden 1.
    • Remove the four 8 mm JIS #1 screws that were revealed after removing the set of gears.
    • There will be lubricant on the screws.
  13. Hamilton Beach 70730 Motor Replacement: adım 13, 1 resimden 1.
    • Flip the device over so the bottom is visible.
  14. Hamilton Beach 70730 Motor Replacement: adım 14, 1 resimden 1.
    • Using a JIS #1 screwdriver, remove each of the four suction cups that are attached to the bottom of the food processor.
  15. Hamilton Beach 70730 Motor Replacement: adım 15, 1 resimden 1.
    • Using a JIS #1 screwdriver, remove the four 12 mm screws on the bottom.
    • The screws are recessed about 3 mm inside of the device and may not be easily visible.
  16. Hamilton Beach 70730 Motor Replacement: adım 16, 1 resimden 1.
    • Remove the two 4 mm screws underneath the on/off switch with a JIS #1 screwdriver.
  17. Hamilton Beach 70730 Motor Replacement: adım 17, 1 resimden 1.
    • Pull the bottom plate away from the base.
  18. Hamilton Beach 70730 Motor Replacement: adım 18, 1 resimden 1.
    • Using a JIS # 1 screwdriver, remove the three screws on the white bracket.
  19. Hamilton Beach 70730 Motor Replacement: adım 19, 1 resimden 1.
    • Remove the white bracket and guide the wires away from their holders. Be careful not to dislodge the spring held inside the base.
    • Be careful not to dislodge the spring on the cylindrical white piece next to it.
  20. Hamilton Beach 70730 Motor Replacement: adım 20, 1 resimden 1.
    • The motor can now be removed from the inside of the food processor.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Mack Bernard
597 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-4, Isaacson Spring 2016 UMass Dartmouth, Team 2-4, Isaacson Spring 2016 üyesi
UMASSD-ISAACSON-S16S2G4
3 Üyeler
5 Yorum
Thanks for the guide! I would never have thought to dig through the grease in the gearbox to find the 4 machine screws buried under there. Turns out that my motor is fine, but the thermal fuse strapped to the windings burned out. $5 fix for a $150 device!
Louis H - Yanıt
I didnt see any thermal fuse
Micah the Challenger -
On the bottom of the motor, connected to red lead, wrapped in white shielding
Fidel Cashflow - Yanıt
My Hamilton Beach food processor stopped working. So I ordered another bottom part(motor assembly) but t it will not come on either. Are they not interchangeable?
nelda lowe - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 40
Her zaman: 6,154
