Ana içeriğe geç
Hamilton Beach 70740 Internal switch Replacement
Neye ihtiyacın var
    1. Hamilton Beach 70740 Internal switch Replacement, Bowl and Lid: adım 1, 2 resimden 1. Hamilton Beach 70740 Internal switch Replacement, Bowl and Lid: adım 1, 2 resimden 2.
      • Turn the bowl counterclockwise and lift.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Internal switch Replacement, Power Knob: adım 2, 3 resimden 1. Hamilton Beach 70740 Internal switch Replacement, Power Knob: adım 2, 3 resimden 2. Hamilton Beach 70740 Internal switch Replacement, Power Knob: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      Heavy-Duty Spudger
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Internal switch Replacement, Base: adım 3, 2 resimden 1. Hamilton Beach 70740 Internal switch Replacement, Base: adım 3, 2 resimden 2.
      • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
      • Pull suction cups straight out.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Internal switch Replacement: adım 4, 3 resimden 1. Hamilton Beach 70740 Internal switch Replacement: adım 4, 3 resimden 2. Hamilton Beach 70740 Internal switch Replacement: adım 4, 3 resimden 3.
      Heavy-Duty Spudger
      • Remove rubber caps using the heavy duty spudger.
      • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
      • Pull base straight out.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Internal switch Replacement, Internal switch: adım 5, 2 resimden 1. Hamilton Beach 70740 Internal switch Replacement, Internal switch: adım 5, 2 resimden 2.
      • Remove the two 11 mm screws using the #2 Phillips head screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Internal switch Replacement: adım 6, 2 resimden 1. Hamilton Beach 70740 Internal switch Replacement: adım 6, 2 resimden 2.
      • Cut all four red wires using the wire stripper crimping tool.
      • Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
      • Cut the white wire using the stripper crimping tool.
      • Using the wire stripper crimping tool strip the ends of each of the white wires and insert them into the opposite ends of a parallel connector, then crimp firmly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Travis Williams
552 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-4, Blackwell Spring 2017 USF Tampa, Team 17-4, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S17G4
3 Üyeler
21 adet Kılavuz yazıldı
2Kılavuz Yorumları
On our unit the control knob became stuck. Where can I get a new control knob? Do you happen to know the part number?
Mitchell Arends - Yanıt Paylaş
I used a hair dryer and that did the trick, but am wondering if WD 40 would work as well. I went online e with the company and they want $2.00 for tech advice which is dumb to me. At first I thought it was the locking device on top; it is actually the pulse switch and my machine is just over a year old.
joanneferrato - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 1,326
