Ana içeriğe geç
Hamilton Beach 70740 Motor Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. Hamilton Beach 70740 Motor Replacement, Base Removal: adım 1, 3 resimden 1. Hamilton Beach 70740 Motor Replacement, Base Removal: adım 1, 3 resimden 2. Hamilton Beach 70740 Motor Replacement, Base Removal: adım 1, 3 resimden 3.
      • Hold the food processor upside down and remove the two screws indicated with a screwdriver. Once unscrewed, remove the two rubber suction pads.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Motor Replacement: adım 2, 2 resimden 1. Hamilton Beach 70740 Motor Replacement: adım 2, 2 resimden 2.
      • Use a spudger to remove the 4 rubber base pads located at the corners of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 70740 Motor Replacement: adım 3, 1 resimden 1.
      • Unscrew all 4 screws that are located beneath the pads with a screwdriver and remove the plastic grey base.
      FixBot'a Sor
      Yorum Ekle
    4. Hamilton Beach 70740 Motor Replacement: adım 4, 1 resimden 1.
      • Remove the screws indicated with a screw driver.
      FixBot'a Sor
      Yorum Ekle
    5. Hamilton Beach 70740 Motor Replacement: adım 5, 1 resimden 1.
      • Remove the two screws behind the knob with a screwdriver.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Motor Replacement, Motor/Cord: adım 6, 1 resimden 1.
      • Use a regular nylon spudger to remove the plastic caps at these locations with moderate pressure.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      • Apply pressure at the edge of the plastic cap circles. Apply stress elsewhere may damage the device.
      • Note that the plastic caps are glued
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Motor Replacement: adım 7, 1 resimden 1.
      • Remove the 4 screws located under the plastic caps with a screw driver.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 70740 Motor Replacement: adım 8, 2 resimden 1. Hamilton Beach 70740 Motor Replacement: adım 8, 2 resimden 2.
      • Lift and remove the plastic gears at the center of the device.
      • Remove any grease residue underneath the plastic gears.
      FixBot'a Sor
      Yorum Ekle
    4. Hamilton Beach 70740 Motor Replacement: adım 9, 2 resimden 1. Hamilton Beach 70740 Motor Replacement: adım 9, 2 resimden 2.
      • Remove the remaining screws to unhinge the motor located at the center of the device using a screw driver.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Motor Replacement, Motor: adım 10, 1 resimden 1.
      • Remove to electrical cap to the positive terminal(black terminal), and undo the wiring.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Motor Replacement: adım 11, 1 resimden 1.
      • Remove the electrical cap to the negative end(red wire), and undo the wiring. Once this is complete reconstruct the wiring with the new motor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
David Gedeon
806 İtibar
6 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Baechle Fall 2015 IUPUI, Team 1-1, Baechle Fall 2015 üyesi
IUPUI-BAECHLE-F15S1G1
4 Üyeler
26 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 26
Her zaman: 841
