Ana içeriğe geç
Hamilton Beach 70740 Motor Replacement
Neye ihtiyacın var
    1. Hamilton Beach 70740 Motor Replacement, Bowl and Lid: adım 1, 2 resimden 1. Hamilton Beach 70740 Motor Replacement, Bowl and Lid: adım 1, 2 resimden 2.
      • Turn the bowl counterclockwise and lift.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Motor Replacement, Gears: adım 2, 2 resimden 1. Hamilton Beach 70740 Motor Replacement, Gears: adım 2, 2 resimden 2.
      • Use the nylon spudger to remove the plastic screw covers.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Motor Replacement: adım 3, 3 resimden 1. Hamilton Beach 70740 Motor Replacement: adım 3, 3 resimden 2. Hamilton Beach 70740 Motor Replacement: adım 3, 3 resimden 3.
      • Using a #2 Phillips head screwdriver, remove the four 10 mm screws and pull the shaft straight upwards to uncover gears.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 70740 Motor Replacement: adım 4, 2 resimden 1. Hamilton Beach 70740 Motor Replacement: adım 4, 2 resimden 2.
      • Firmly grasp center piece of gear mechanism and pull straight upward.
      FixBot'a Sor
      Yorum Ekle
    1. Hamilton Beach 70740 Motor Replacement, Motor: adım 5, 2 resimden 1. Hamilton Beach 70740 Motor Replacement, Motor: adım 5, 2 resimden 2.
      • Using a #2 Phillips head screwdriver, remove the two 11 mm screws and pull the rubber suction cups straight up.
      FixBot'a Sor
      Yorum Ekle
    2. Hamilton Beach 70740 Motor Replacement: adım 6, 3 resimden 1. Hamilton Beach 70740 Motor Replacement: adım 6, 3 resimden 2. Hamilton Beach 70740 Motor Replacement: adım 6, 3 resimden 3.
      • Using the heavy duty plastic spudger remove the four rubber caps.
      • Using a #2 Phillips head screwdriver, remove the four 11 mm screws inside each of the bases legs.
      • Pull the base straight up to remove it from the processor.
      FixBot'a Sor
      Yorum Ekle
    3. Hamilton Beach 70740 Motor Replacement: adım 7, 3 resimden 1. Hamilton Beach 70740 Motor Replacement: adım 7, 3 resimden 2. Hamilton Beach 70740 Motor Replacement: adım 7, 3 resimden 3.
      • Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
      • From the open base pull the motor straight out.
      FixBot'a Sor
      Yorum Ekle
    4. Hamilton Beach 70740 Motor Replacement: adım 8, 2 resimden 1. Hamilton Beach 70740 Motor Replacement: adım 8, 2 resimden 2.
      • Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor.
      • Using the wire stripper crimping tool strip the ends of each of the black cords and insert them into the opposite ends of a parallel connector, then crimp firmly.
      • Using the wire stripper crimping tool cut the four red wire connections from the switch to the motor and then rewire the four red wires together in a wiring connector cap.
      • Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Travis Williams
552 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-4, Blackwell Spring 2017 USF Tampa, Team 17-4, Blackwell Spring 2017 üyesi
USFT-BLACKWELL-S17S17G4
3 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 3,637
